Introduction
Go to step 1 ↓The VGA input transfers information from the computer to the monitor, so having one that is working properly is important.
Parts
Tools
Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
Remove the beige control cable to the left of the VGA input by pulling it up.
Using the soldering iron, desolder the VGA input at the indicated locations.
Solder the new VGA input into the circuit board at the same locations.
Click here for more information on component-level soldering.
