Up to 20% off select tools
Acer AL1916 Stand Replacement
Views: 22K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
152
All Time:
21,731
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
The stand supports the monitor from falling over.
    1. Acer AL1916 Stand Replacement, Stand: step 1, image 1 of 1
      • Lay the monitor on a flat surface so that the back is facing up.
      Ask FixBot
    2. Acer AL1916 Stand Replacement: step 2, image 1 of 2 Acer AL1916 Stand Replacement: step 2, image 2 of 2
      • Grab the hinge cover with both hands on either side of the stand.
      • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
      Ask FixBot
    3. Acer AL1916 Stand Replacement: step 3, image 1 of 2 Acer AL1916 Stand Replacement: step 3, image 2 of 2
      • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
      • Support the monitor while removing the screws to prevent the monitor from falling.
      • Lift up to detach the stand.
      Ask FixBot
8 other people completed this guide.
Author
with
Keith
375 Reputation
4 Guides authored
Cal Poly, Team 20-26, Maness Fall 2011 Member of Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Members
84 Guides authored
2 Guide Comments
Worked great…never would have guessed how to do it. Thanks.
GREG HILL - Reply Share
I would never have worked out how to remove the stand without this - thank you.
Mark Philipson - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 152
All Time: 21,731
