Acer AL1714 Video Display Board
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
101
All Time:
1,498
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Acer AL1714 Video Display Board, Video Display Board: step 1, image 1 of 2 Acer AL1714 Video Display Board, Video Display Board: step 1, image 2 of 2
      • Turn the monitor face-down.
      • Unscrew the 5 screws holding back cover on.
      • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
      Ask FixBot
    2. Acer AL1714 Video Display Board: step 2, image 1 of 3 Acer AL1714 Video Display Board: step 2, image 2 of 3 Acer AL1714 Video Display Board: step 2, image 3 of 3
      • Take the edge tool or a metal ruler and insert it into the bezel.
      • Apply pressure and push down.
      • Do the same to the right side.
      • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
      Ask FixBot
    3. Acer AL1714 Video Display Board: step 3, image 1 of 3 Acer AL1714 Video Display Board: step 3, image 2 of 3 Acer AL1714 Video Display Board: step 3, image 3 of 3
      • Remove the Flat Flex Cable from the Power Supply board located under the metal cage.
      • Pull the cord back and out of the way.
      • (It may be stuck down with adhesive)
      Ask FixBot
    4. Acer AL1714 Video Display Board: step 4, image 1 of 3 Acer AL1714 Video Display Board: step 4, image 2 of 3 Acer AL1714 Video Display Board: step 4, image 3 of 3
      • Unscrew the cord anchors for the VGA port.
      • (Use needle nose pliers if they're too tight for removal by hand)
      Ask FixBot
    5. Acer AL1714 Video Display Board: step 5, image 1 of 2 Acer AL1714 Video Display Board: step 5, image 2 of 2
      • Turn the monitor around.
      • Unscrew the 1 screw holding the Flat power Cable cover on.
      • Lift up and remove the Flat Power Cable cover.
      • (Careful: this may be sharp)
      Ask FixBot
    6. Acer AL1714 Video Display Board: step 6, image 1 of 1
      • Unscrew the 5 screws holding the metal cage on.
      Ask FixBot
    7. Acer AL1714 Video Display Board: step 7, image 1 of 2 Acer AL1714 Video Display Board: step 7, image 2 of 2
      • Lift the back of the metal cage slightly.
      • Pull the cage toward self.
      • (Must be careful to free the cover of the VGA port and the power supply input)
      Ask FixBot
    8. Acer AL1714 Video Display Board: step 8, image 1 of 3 Acer AL1714 Video Display Board: step 8, image 2 of 3 Acer AL1714 Video Display Board: step 8, image 3 of 3
      • Lift the Flat Flex Cable holder tabs to release the cables.
      • Lift up on the Flat Flex Cables and bend them out of the working area.
      Ask FixBot
    9. Acer AL1714 Video Display Board: step 9, image 1 of 3 Acer AL1714 Video Display Board: step 9, image 2 of 3 Acer AL1714 Video Display Board: step 9, image 3 of 3
      • Unplug the 4 backlight wires from their ports on the Power Supply Board.
      • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling the wires out of place)
      Ask FixBot
    10. Acer AL1714 Video Display Board: step 10, image 1 of 1
      • Unscrew the 5 screws holding the Power Supply and Video Display boards.
      Ask FixBot
    11. Acer AL1714 Video Display Board: step 11, image 1 of 2 Acer AL1714 Video Display Board: step 11, image 2 of 2
      • Lift and remove the joined boards.
      Ask FixBot
    12. Acer AL1714 Video Display Board: step 12, image 1 of 3 Acer AL1714 Video Display Board: step 12, image 2 of 3 Acer AL1714 Video Display Board: step 12, image 3 of 3
      • Carefully detach the two boards at their connector joint.
      • Replace outlined part.
      Ask FixBot
2 other people completed this guide.
Christopher Kelly
590 Reputation
4 Guides authored
USF Tampa, Team 1-3, Brown Fall 2014 Member of USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 101
All Time: 1,498
