Acer AL1714 Power Button Circuit Board
    1. Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: step 1, image 1 of 2 Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: step 1, image 2 of 2
      • Turn the monitor facedown.
      • Unscrew the 5 screws holding the back cover on.
      • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
      Ask FixBot
    2. Acer AL1714 Power Button Circuit Board: step 2, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 2, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 2, image 3 of 3
      • Take the edge tool or a metal ruler and insert it into the bezel.
      • Apply pressure and push down.
      • Do the same to the right side.
      • Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
      Ask FixBot
    3. Acer AL1714 Power Button Circuit Board: step 3, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 3, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 3, image 3 of 3
      • Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
      • Pull the cord back and out of the way.
      • (It may be stuck down with adhesive)
      Ask FixBot
    4. Acer AL1714 Power Button Circuit Board: step 4, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 4, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 4, image 3 of 3
      • Unscrew the cord anchors for the VGA port.
      • (Use needle nose pliers if they're too tight for removal by hand)
      Ask FixBot
    5. Acer AL1714 Power Button Circuit Board: step 5, image 1 of 2 Acer AL1714 Power Button Circuit Board: step 5, image 2 of 2
      • Turn the monitor around.
      • Unscrew the 1 screw holding the Flex Power Cable cover.
      • Lift up and remove the Flex Power Cable cover.
      • (Careful: This may be sharp)
      Ask FixBot
    6. Acer AL1714 Power Button Circuit Board: step 6, image 1 of 1
      • Unscrew the 5 screws holding the metal cage on.
      Ask FixBot
    7. Acer AL1714 Power Button Circuit Board: step 7, image 1 of 2 Acer AL1714 Power Button Circuit Board: step 7, image 2 of 2
      • Lift up on the back of the metal cage slightly.
      • Pull the cage toward self.
      • (Must be careful to free the cover of the VGA port and power supply input)
      Ask FixBot
    8. Acer AL1714 Power Button Circuit Board: step 8, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 8, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 8, image 3 of 3
      • Lift up on the Flat Flex Cable holder tabs to release cords.
      • Lift up on the Flat Flex Cables and bend them out of the working area.
      Ask FixBot
    9. Acer AL1714 Power Button Circuit Board: step 9, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 9, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 9, image 3 of 3
      • Unplug the 4 backlight wires from their ports on the Power Supply Board.
      • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling wires out of place)
      Ask FixBot
    10. Acer AL1714 Power Button Circuit Board: step 10, image 1 of 1
      • Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
      Ask FixBot
    11. Acer AL1714 Power Button Circuit Board: step 11, image 1 of 2 Acer AL1714 Power Button Circuit Board: step 11, image 2 of 2
      • Lift up and remove the joined Power Supply Board and Video Display boards.
      Ask FixBot
    12. Acer AL1714 Power Button Circuit Board: step 12, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 12, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 12, image 3 of 3
      • Carefully detach the Power Supply and Video Display boards at their connector joint.
      • (This step is not necessary for the removal and replacement of the Power Button Circuit board)
      • (This is only a precaution so as not to bend or break the connector joint between the two boards)
      Ask FixBot
    13. Acer AL1714 Power Button Circuit Board: step 13, image 1 of 1
      • Remove the Flat Flex Cable from the Power Button Circuit Board.
      Ask FixBot
    14. Acer AL1714 Power Button Circuit Board: step 14, image 1 of 3 Acer AL1714 Power Button Circuit Board: step 14, image 2 of 3 Acer AL1714 Power Button Circuit Board: step 14, image 3 of 3
      • Grasp, lift, and remove the LCD Module from the front panel.
      Ask FixBot
    15. Acer AL1714 Power Button Circuit Board: step 15, image 1 of 2 Acer AL1714 Power Button Circuit Board: step 15, image 2 of 2
      • Unscrew the 2 screws holding the Power Button Circuit Board.
      Ask FixBot
    16. Acer AL1714 Power Button Circuit Board: step 16, image 1 of 1
      • Lift and remove the Power Button Circuit Board.
      Ask FixBot
3 other people completed this guide.
Hussam Alzamzami
216 Reputation
1 Guide authored
USF Tampa, Team 1-3, Brown Fall 2014 Member of USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 63
All Time: 2,147
