Accu-Chek Guide Diabetes Meter Battery Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
26
Past 7 Days:
159
Past 30 Days:
747
All Time:
5,517
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Is your Accu-Chek Guide Diabetes Meter out of power? Follow these easy instructions to change the battery and maintain accurate continuous monitoring of your blood glucose.
Changing the battery is a necessary maintenance activity. Maintaining the Accu-Chek Guide Diabetes Meter's power supply is essential for reliable blood sugar readings, as it plays a critical role in tracking your health.
Before you begin this guide, be sure to turn off your device.
Parts
Tools
  • Small Plastic Spudger
    4.9
    1. Accu-Chek Guide Diabetes Meter Battery Replacement, Battery: step 1, image 1 of 2 Accu-Chek Guide Diabetes Meter Battery Replacement, Battery: step 1, image 2 of 2
      • Press the OK button to make sure the meter is turned off.
      • Turn the device over and look for the latch on the back of the battery compartment.
      Ask FixBot
    2. Accu-Chek Guide Diabetes Meter Battery Replacement: step 2, image 1 of 2 Accu-Chek Guide Diabetes Meter Battery Replacement: step 2, image 2 of 2
      • Push the latch toward the battery door to release the lock, then lift the battery door to remove it.
      Ask FixBot
    3. Accu-Chek Guide Diabetes Meter Battery Replacement: step 3, image 1 of 3 Accu-Chek Guide Diabetes Meter Battery Replacement: step 3, image 2 of 3 Accu-Chek Guide Diabetes Meter Battery Replacement: step 3, image 3 of 3
      • Use a plastic spudger near the middle right side of the top 3V battery to pry it from the battery holder.
      • Press down on the middle of the battery holder to eject the bottom battery.
      Ask FixBot
    4. Accu-Chek Guide Diabetes Meter Battery Replacement: step 4, image 1 of 2 Accu-Chek Guide Diabetes Meter Battery Replacement: step 4, image 2 of 2
      • Slide the new 3V battery in the top slot, then press down to secure it in place.
      • Replace the 3V battery in the bottom slot.
      • The plus sign on the 3V batteries should face down when placed in each slot.
      Ask FixBot
    5. Accu-Chek Guide Diabetes Meter Battery Replacement: step 5, image 1 of 2 Accu-Chek Guide Diabetes Meter Battery Replacement: step 5, image 2 of 2
      • Carefully slide the cover back into place and push it down to lock it securely.
      Ask FixBot
    6. Accu-Chek Guide Diabetes Meter Battery Replacement: step 6, image 1 of 2 Accu-Chek Guide Diabetes Meter Battery Replacement: step 6, image 2 of 2
      • Press and hold the OK button for 5-7 seconds to reactivate the meter.
      • Observe the display to confirm the successful reactivation before using the Accu-Chek Guide Diabetes Meter.
      • If you are reactivating the meter after a period of inactivity, it may take a few extra seconds to initialize.
      Ask FixBot
With the successful replacement of the batteries and reactivation of the Accu-Chek Guide Meter, the device is fully operational, ready to provide accurate and reliable readings.
4 other people completed this guide.
Syed Ahmed
208 Reputation
1 Guide authored
2 Guide Comments
Text says "2016" batteries. Photograph shows 2032 batteries ! ! !
Janet Appleby - Reply Share
Hi Janet, thank you so much for letting us know about the incorrect batteries in the parts list. We’ve updated it, and we really appreciate your help in keeping the guide accurate.
Sarah Westberg - Reply Share
Past 24 Hours: 26
Past 7 Days: 159
Past 30 Days: 747
All Time: 5,517
