Accessing Logicboard
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
114
All Time:
2,195
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide you will learn how to remove the SD card circuit board to access the logic board. To access the logic board, you will need to unsolder two leads. For soldering instructions, please refer to steps 1 through 6 of this soldering guide.
Tools
    1. Accessing Logicboard, Front and Back Cover: step 1, image 1 of 2 Accessing Logicboard, Front and Back Cover: step 1, image 2 of 2
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
      Ask FixBot
    2. Accessing Logicboard: step 2, image 1 of 1
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
      Ask FixBot
    3. Accessing Logicboard: step 3, image 1 of 2 Accessing Logicboard: step 3, image 2 of 2
      • Carefully pull the back of casing away from the front.
      Ask FixBot
    4. Accessing Logicboard: step 4, image 1 of 3 Accessing Logicboard: step 4, image 2 of 3 Accessing Logicboard: step 4, image 3 of 3
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
      Ask FixBot
    5. Accessing Logicboard: step 5, image 1 of 2 Accessing Logicboard: step 5, image 2 of 2
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
      Ask FixBot
    1. Accessing Logicboard, Logicboard: step 6, image 1 of 2 Accessing Logicboard, Logicboard: step 6, image 2 of 2
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
      Ask FixBot
    2. Accessing Logicboard: step 7, image 1 of 2 Accessing Logicboard: step 7, image 2 of 2
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
      Ask FixBot
    3. Accessing Logicboard: step 8, image 1 of 1
      • Pull the cover plate off for the two power cord jacks.
      Ask FixBot
    4. Accessing Logicboard: step 9, image 1 of 3 Accessing Logicboard: step 9, image 2 of 3 Accessing Logicboard: step 9, image 3 of 3
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
      Ask FixBot
    5. Accessing Logicboard: step 10, image 1 of 1
      • Remove the orange tape on top of the SD cardholder.
      Ask FixBot
    6. Accessing Logicboard: step 11, image 1 of 1
      • Open the battery cover.
      Ask FixBot
    7. Accessing Logicboard: step 12, image 1 of 2 Accessing Logicboard: step 12, image 2 of 2
      • Lift the indicated plastic piece off.
      Ask FixBot
    8. Accessing Logicboard: step 13, image 1 of 2 Accessing Logicboard: step 13, image 2 of 2
      • Remove screws indicated:
      • Two black 4.80mm Phillips #00 screws
      Ask FixBot
    9. Accessing Logicboard: step 14, image 1 of 1
      • Unsolder points indicated.
      • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
      Ask FixBot
    10. Accessing Logicboard: step 15, image 1 of 3 Accessing Logicboard: step 15, image 2 of 3 Accessing Logicboard: step 15, image 3 of 3
      • Carefully lift up SD cardholder to reveal logicboard.
      Ask FixBot
Nicole Wong
371 Reputation
3 Guides authored
Cal Poly, Team 4-29, Regan Winter 2011 Member of Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 114
All Time: 2,195
