Accessing Apple Cinema Display M8149 Control Boards
    1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: step 1, image 1 of 3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: step 1, image 2 of 3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: step 1, image 3 of 3
      • Before starting, make sure the display is unplugged.
      • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
      • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
      • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
      Ask FixBot
    2. Accessing Apple Cinema Display M8149 Control Boards: step 2, image 1 of 3 Accessing Apple Cinema Display M8149 Control Boards: step 2, image 2 of 3 Accessing Apple Cinema Display M8149 Control Boards: step 2, image 3 of 3
      • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
      • Disconnect the small white connector leading to the display's Power button.
      • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
      Ask FixBot
    3. Accessing Apple Cinema Display M8149 Control Boards: step 3, image 1 of 2 Accessing Apple Cinema Display M8149 Control Boards: step 3, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
      • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
      Ask FixBot
    4. Accessing Apple Cinema Display M8149 Control Boards: step 4, image 1 of 3 Accessing Apple Cinema Display M8149 Control Boards: step 4, image 2 of 3 Accessing Apple Cinema Display M8149 Control Boards: step 4, image 3 of 3
      • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
      • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
      Ask FixBot
    5. Accessing Apple Cinema Display M8149 Control Boards: step 5, image 1 of 2 Accessing Apple Cinema Display M8149 Control Boards: step 5, image 2 of 2
      • Gently lift the large metal cover which spans across the back of the whole display.
      Ask FixBot
3 other people completed this guide.
Brett Murphy
199 Reputation
3 Guides authored
Cal Poly, Team 10-41, Forte Spring 2011 Member of Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Members
72 Guides authored
1 Guide Comment
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 41
All Time: 6,400
