Access to RAM and CPU from why! W253EU
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
89
All Time:
724
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
    1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 1 of 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 2 of 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 3 of 3
      • Turn off the computer.
      • Before each operation it is important to start with the removal of the accumulator.
      • Take the slide unlocked into position, remove the battery.
      Ask FixBot
    1. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 1 of 2 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 2 of 2
      • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
      Ask FixBot
    2. Access to RAM and CPU from why! W253EU: step 3, image 1 of 3 Access to RAM and CPU from why! W253EU: step 3, image 2 of 3 Access to RAM and CPU from why! W253EU: step 3, image 3 of 3
      • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
      • Now lift the cover carefully.
      • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
      Ask FixBot
    3. Access to RAM and CPU from why! W253EU: step 4, image 1 of 1
      • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
      Ask FixBot
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 89
All Time: 724
