Introduction
In this guide, we will be replacing the spool on the Abu Garcia Black Max bait casting reel.
The typical spool on a bait casting reel should last an extremely long time and does not need to be typically replaced. On the other hand, if you use your reel in salt water without proper maintenance, the spool could corrode.
This guide will begin with the removal of the spool, following a few simple steps, then taking the old spool and replacing it with the new spool. Finally, we will reassemble the reel back together.
If you have found your spool to be damaged, corroded, or just want to switch it out with a new spool, this guide is for you.
