Abask A8 Speaker Replacement
  1. Abask A8 Speaker Replacement, Internal Assembly: step 1, image 1 of 3 Abask A8 Speaker Replacement, Internal Assembly: step 1, image 2 of 3 Abask A8 Speaker Replacement, Internal Assembly: step 1, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws on the front plate.
    • Gently insert a pry between the front panel and the main body, working around the edges to pop it off.
    • Pull the main body from the shell.
    • Be careful not to damage the ribbon cable, as they are very fragile. Ribbon cables look like thin pieces of silver duct-tape.
    Ask FixBot
  2. Abask A8 Speaker Replacement: step 2, image 1 of 2 Abask A8 Speaker Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the screen.
    Ask FixBot
  3. Abask A8 Speaker Replacement: step 3, image 1 of 3 Abask A8 Speaker Replacement: step 3, image 2 of 3 Abask A8 Speaker Replacement: step 3, image 3 of 3
    • Remove the internal facing camera with care not to strain the connected ribbon cable.
    • Lift up the black ZIF locking flap and disconnect the ribbon cable.
    Ask FixBot
  4. Abask A8 Speaker Replacement: step 4, image 1 of 3 Abask A8 Speaker Replacement: step 4, image 2 of 3 Abask A8 Speaker Replacement: step 4, image 3 of 3
    • Lift the camera connector ZIF locking flap.
    • Gently remove the ribbon cable from the connector and fully remove the camera.
    Ask FixBot
  5. Abask A8 Speaker Replacement: step 5, image 1 of 2 Abask A8 Speaker Replacement: step 5, image 2 of 2
    • Using a Jimmy prying tool, lift the supercapacitor out of its slot.
    • Be careful not to puncture the supercapacitor.
    Ask FixBot
  6. Abask A8 Speaker Replacement, Motherboard: step 6, image 1 of 2 Abask A8 Speaker Replacement, Motherboard: step 6, image 2 of 2
    • Lift the ZIF locking flap that is securing the ribbon cable connecting the motherboard to the shell.
    Ask FixBot
  7. Abask A8 Speaker Replacement: step 7, image 1 of 2 Abask A8 Speaker Replacement: step 7, image 2 of 2
    • Gently lift the ribbon cable locking flap and disconnect the ribbon cable from the motherboard.
    • Carefully separate the motherboard from the screen.
    Ask FixBot
  8. Abask A8 Speaker Replacement, Photodiode: step 8, image 1 of 1
    • Gently release the silver locking flap that is holding the ribbon cable connecting the photodiode to the motherboard.
    • Carefully pull the flat ribbon cable out of the connector.
    Ask FixBot
  9. Abask A8 Speaker Replacement: step 9, image 1 of 2 Abask A8 Speaker Replacement: step 9, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the photodiode.
    • Carefully lift the old photodiode out of its base.
    • To avoid damaging the photodiode, make sure to place it face down on a clean, static-free surface when not handling it.
    Ask FixBot
  10. Abask A8 Speaker Replacement, Speaker: step 10, image 1 of 3 Abask A8 Speaker Replacement, Speaker: step 10, image 2 of 3 Abask A8 Speaker Replacement, Speaker: step 10, image 3 of 3
    • Removing the photodiode will expose the speaker, connected by wires.
    • Using a soldering iron, desolder the speaker connections from the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lindsey Fennell
341 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 190
