Up to 20% off select tools
AYL SoundFit Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
106
All Time:
3,638
Comments: 4
4 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery of your AYL SoundFit. If your device's battery won't hold a charge, replacing the battery may resolve the problem.
    1. AYL SoundFit Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
      Ask FixBot
    2. AYL SoundFit Battery Replacement: step 2, image 1 of 1
      • Place a spudger between the black plastic cover and the green case.
      • Pry the black cover away from the main casing and remove the cover.
      Ask FixBot
    3. AYL SoundFit Battery Replacement: step 3, image 1 of 1
      • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
      • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
      Ask FixBot
    4. AYL SoundFit Battery Replacement: step 4, image 1 of 2 AYL SoundFit Battery Replacement: step 4, image 2 of 2
      • Remove the two Phillips #00 screws securing the battery casing.
      • Remove the battery case to reveal the battery.
      Ask FixBot
    5. AYL SoundFit Battery Replacement: step 5, image 1 of 1
      • Desolder the positive and negative battery contacts from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
Author
with
Dustin Moore
108 Reputation
1 Guide authored
IUPUI, Team 3-3, Harley Spring 2016 Member of IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Members
60 Guides authored
4 Guide Comments
Which battery is this, and what is the mAH?
jlongsa - Reply Share
3.7V 1500mAh, 5.55Wh
Coba Farr - Reply Share
The charger works but it does not say chargeing
Zaira Cortes - Reply Share
18650 battery
rich4349 - Reply Share
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 106
All Time: 3,638
