AXIOO Pico M1110 PJM Keyboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
83
All Time:
1,136
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. AXIOO Pico M1110 PJM Keyboard Replacement, Underside: step 1, image 1 of 1
      • Identify the battery locker.
      • Set the righthand locker to unlock.
      • Pull the battery while setting the lefthand locker to unlock.
      Ask FixBot
    2. AXIOO Pico M1110 PJM Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. AXIOO Pico M1110 PJM Keyboard Replacement, Keyboard: step 3, image 1 of 3 AXIOO Pico M1110 PJM Keyboard Replacement, Keyboard: step 3, image 2 of 3 AXIOO Pico M1110 PJM Keyboard Replacement, Keyboard: step 3, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Identify these:
      • 4 keyboard clipper
      • Remove the keyboard clipper by gently twisting them till pops out.
      • Use a small flathead screwdriver to twist easier.
      • Lift the keyboard up by pivoting on the bottom side.
      • Don't lift it too high up, because beneath it there's the keyboard ZIF connector still connected; refer to the next step.
      Ask FixBot
    2. AXIOO Pico M1110 PJM Keyboard Replacement: step 4, image 1 of 3 AXIOO Pico M1110 PJM Keyboard Replacement: step 4, image 2 of 3 AXIOO Pico M1110 PJM Keyboard Replacement: step 4, image 3 of 3
      Buy
      • Identify this:
      • The ZIF connector locker
      • Gently pull the locker out.
      • Use a pair of tweezers to make it easier to pull it out.
      • Don't forget the other side too!
      • Remove the ZIF connector.
      • Remove the keyboard.
      Ask FixBot
2 other people completed this guide.
Cakra Diaz
1,143 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 83
All Time: 1,136
