ATT Trimline 210M Speaker Replacement
  1. ATT Trimline 210M Speaker Replacement, Back Cover: step 1, image 1 of 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
    Ask FixBot
  2. ATT Trimline 210M Speaker Replacement: step 2, image 1 of 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
    Ask FixBot
  3. ATT Trimline 210M Speaker Replacement: step 3, image 1 of 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
    Ask FixBot
  4. ATT Trimline 210M Speaker Replacement: step 4, image 1 of 1
    • You will have the motherboard and speaker exposed to you.
    Ask FixBot
  5. ATT Trimline 210M Speaker Replacement, Motherboard: step 5, image 1 of 1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
    Ask FixBot
  6. ATT Trimline 210M Speaker Replacement: step 6, image 1 of 1
    • Carefully move the motherboard up to remove it.
    Ask FixBot
  7. ATT Trimline 210M Speaker Replacement, Speaker: step 7, image 1 of 1
    • Carefully detach the black and red wires
    Ask FixBot
  8. ATT Trimline 210M Speaker Replacement: step 8, image 1 of 1
    • Use the iFixit iOpener to warm the adhesive from the front of the phone, in order to remove the speaker from the face plate safely.
    Ask FixBot
  9. ATT Trimline 210M Speaker Replacement: step 9, image 1 of 1
    • Remove speaker
    Ask FixBot
Corey
343 Reputation
3 Guides authored
USF Tampa, Team 4-2, Lacy Spring 2016 Member of USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 43
All Time: 669
