ATT Trimline 210M Motherboard Replacement
  1. ATT Trimline 210M Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
    Ask FixBot
  2. ATT Trimline 210M Motherboard Replacement: step 2, image 1 of 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
    Ask FixBot
  3. ATT Trimline 210M Motherboard Replacement: step 3, image 1 of 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
    Ask FixBot
  4. ATT Trimline 210M Motherboard Replacement: step 4, image 1 of 1
    • You will have the motherboard and speaker exposed to you.
    Ask FixBot
  5. ATT Trimline 210M Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
    Ask FixBot
  6. ATT Trimline 210M Motherboard Replacement: step 6, image 1 of 1
    • Carefully move the motherboard up to remove it.
    Ask FixBot
2 other people completed this guide.
Juan Carrillo
406 Reputation
3 Guides authored
USF Tampa, Team 4-2, Lacy Spring 2016 Member of USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,308
