Up to 20% off select tools
ATT Trek HD Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
48
All Time:
482
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the front camera in an ATT Trek HD tablet. The camera may need to be replaced, if it will no longer stay in focus or seems blurry. This part is moderately difficult to remove, and will require you to remove the motherboard from the device. This will require you to use a plastic opening tool, angled tweezers, and a PH00 screwdriver.
    1. ATT Trek HD Front Camera Replacement, Back Cover: step 1, image 1 of 1
      • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
      Ask FixBot
    2. ATT Trek HD Front Camera Replacement: step 2, image 1 of 1
      • Pull the screen away from the back panel.
      Ask FixBot
    1. ATT Trek HD Front Camera Replacement, Battery: step 3, image 1 of 2 ATT Trek HD Front Camera Replacement, Battery: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
      Ask FixBot
    2. ATT Trek HD Front Camera Replacement: step 4, image 1 of 2 ATT Trek HD Front Camera Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to disconnect the black battery connector.
      • Gently lift the battery out of the device.
      Ask FixBot
    1. ATT Trek HD Front Camera Replacement, Motherboard: step 5, image 1 of 2 ATT Trek HD Front Camera Replacement, Motherboard: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
      Ask FixBot
    2. ATT Trek HD Front Camera Replacement: step 6, image 1 of 2 ATT Trek HD Front Camera Replacement: step 6, image 2 of 2
      • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
      Ask FixBot
    3. ATT Trek HD Front Camera Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
      Ask FixBot
    4. ATT Trek HD Front Camera Replacement: step 8, image 1 of 2 ATT Trek HD Front Camera Replacement: step 8, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Use angled tweezers to pry up the black tab.
      • Use the angled tweezers to pull out the gold connector.
      Ask FixBot
    5. ATT Trek HD Front Camera Replacement: step 9, image 1 of 2 ATT Trek HD Front Camera Replacement: step 9, image 2 of 2
      • Use the angled tweezers to disconnect the gold connector.
      Ask FixBot
    6. ATT Trek HD Front Camera Replacement: step 10, image 1 of 1
      • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
      Ask FixBot
    7. ATT Trek HD Front Camera Replacement: step 11, image 1 of 2 ATT Trek HD Front Camera Replacement: step 11, image 2 of 2
      • Use the plastic opening tool to lift the motherboard out of place.
      Ask FixBot
    1. ATT Trek HD Front Camera Replacement, Front Camera: step 12, image 1 of 2 ATT Trek HD Front Camera Replacement, Front Camera: step 12, image 2 of 2
      $3.99
      Buy
      Ask FixBot
Author
with
Jacob Cross
484 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 482
