ATT EL52300 Speaker Replacement
  1. ATT EL52300 Speaker Replacement, Battery: step 1, image 1 of 2 ATT EL52300 Speaker Replacement, Battery: step 1, image 2 of 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
    Ask FixBot
  2. ATT EL52300 Speaker Replacement: step 2, image 1 of 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
    Ask FixBot
  3. ATT EL52300 Speaker Replacement, Motherboard: step 3, image 1 of 2 ATT EL52300 Speaker Replacement, Motherboard: step 3, image 2 of 2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
    Ask FixBot
  4. ATT EL52300 Speaker Replacement: step 4, image 1 of 2 ATT EL52300 Speaker Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
    Ask FixBot
  5. ATT EL52300 Speaker Replacement: step 5, image 1 of 2 ATT EL52300 Speaker Replacement: step 5, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
    Ask FixBot
  6. ATT EL52300 Speaker Replacement, Speaker: step 6, image 1 of 1
    Ask FixBot
Eddie Barnes
365 Reputation
1 Guide authored
USF Tampa, Team 1-1, Sullivan Spring 2016 Member of USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Members
15 Guides authored
1 Guide Comment
Thanks for info and pictures GOOD JOB Any idea where i can purchase new speaker? Phone was dropped and speaker is open
buschy - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 751
