ATT EL52300 Motherboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
81
All Time:
1,191
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
If your handset is encountering difficulties, replacing the motherboard may resolve it. Use the anti-static wrist strap as a precautionary measure to prevent damage to the motherboard.
Tools
    1. ATT EL52300 Motherboard Replacement, Battery: step 1, image 1 of 2 ATT EL52300 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
      Ask FixBot
    2. ATT EL52300 Motherboard Replacement: step 2, image 1 of 1
      • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
      • Do not pull on the wire itself because you might damage the wire!
      • The battery is now detached and ready to be removed by lifting it out.
      Ask FixBot
    1. ATT EL52300 Motherboard Replacement, Motherboard: step 3, image 1 of 2 ATT EL52300 Motherboard Replacement, Motherboard: step 3, image 2 of 2
      • Remove the two 3.75 mm screws with a PH1 screwdriver.
      Ask FixBot
    2. ATT EL52300 Motherboard Replacement: step 4, image 1 of 2 ATT EL52300 Motherboard Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to remove the handset case.
      • Be careful to not lift the case too far as the ringer cable is attached to the case.
      Ask FixBot
    3. ATT EL52300 Motherboard Replacement: step 5, image 1 of 2 ATT EL52300 Motherboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
      • Use an anti-static wrist strap to prevent damage to the motherboard.
      Ask FixBot
Nam Mai
501 Reputation
1 Guide authored
USF Tampa, Team 1-1, Sullivan Spring 2016 Member of USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 81
All Time: 1,191
