ATT EL52300 LCD Screen on Handset Replacement
    1. ATT EL52300 LCD Screen on Handset Replacement, Battery: step 1, image 1 of 2 ATT EL52300 LCD Screen on Handset Replacement, Battery: step 1, image 2 of 2
      • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
      Ask FixBot
    2. ATT EL52300 LCD Screen on Handset Replacement: step 2, image 1 of 1
      • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
      • Do not pull on the wire itself because you might damage the wire!
      • The battery is now detached and ready to be removed by lifting it out.
      Ask FixBot
    1. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: step 3, image 1 of 2 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: step 3, image 2 of 2
      • Remove the two 3.75 mm screws with a PH1 screwdriver.
      Ask FixBot
    2. ATT EL52300 LCD Screen on Handset Replacement: step 4, image 1 of 2 ATT EL52300 LCD Screen on Handset Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to remove the handset case.
      • Be careful to not lift the case too far as the ringer cable is attached to the case.
      Ask FixBot
    3. ATT EL52300 LCD Screen on Handset Replacement: step 5, image 1 of 2 ATT EL52300 LCD Screen on Handset Replacement: step 5, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
      • Use an anti-static wrist strap to prevent damage to the motherboard.
      Ask FixBot
    1. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: step 6, image 1 of 2 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: step 6, image 2 of 2
      • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
      • Pop off the indicated clip using a pointed tweezer.
      • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
      Ask FixBot
    2. ATT EL52300 LCD Screen on Handset Replacement: step 7, image 1 of 3 ATT EL52300 LCD Screen on Handset Replacement: step 7, image 2 of 3 ATT EL52300 LCD Screen on Handset Replacement: step 7, image 3 of 3
      • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
      • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
      Ask FixBot
    3. ATT EL52300 LCD Screen on Handset Replacement: step 8, image 1 of 1
      • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
      • Please refer to the How To Solder and Desolder Connections for soldering help.
      Ask FixBot
Katty
340 Reputation
3 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2016 Member of USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 70
All Time: 872
