ATT EL52300 Keypad/Plastic Display Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
84
All Time:
997
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this keypad replacement guide if buttons are missing or damaged. A potential hazard would be affecting the motherboard through the charge that you internally carry, therefore you should use the anti-static wrist strap to prevent this. References to the other guides will be used.
Tools
    1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: step 1, image 1 of 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: step 1, image 2 of 2
      • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
      Ask FixBot
    2. ATT EL52300 Keypad/Plastic Display Screen Replacement: step 2, image 1 of 1
      • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
      • Do not pull on the wire itself because you might damage the wire!
      • The battery is now detached and ready to be removed by lifting it out.
      Ask FixBot
    1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: step 3, image 1 of 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: step 3, image 2 of 2
      • Remove the two 3.75 mm screws with a PH1 screwdriver.
      Ask FixBot
    2. ATT EL52300 Keypad/Plastic Display Screen Replacement: step 4, image 1 of 2 ATT EL52300 Keypad/Plastic Display Screen Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to remove the handset case.
      • Be careful to not lift the case too far as the ringer cable is attached to the case.
      Ask FixBot
    3. ATT EL52300 Keypad/Plastic Display Screen Replacement: step 5, image 1 of 2 ATT EL52300 Keypad/Plastic Display Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
      • Use an anti-static wrist strap to prevent damage to the motherboard.
      Ask FixBot
    1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: step 6, image 1 of 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: step 6, image 2 of 2
      • The keypad lies on the top of the motherboard and is easily detachable.
      • Remove the keypad.
      Ask FixBot
    2. ATT EL52300 Keypad/Plastic Display Screen Replacement: step 7, image 1 of 1
      • Replace the plastic display screen, or the keypad buttons as needed.
      Ask FixBot
Katty
340 Reputation
3 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2016 Member of USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 84
All Time: 997
