ATT CL4940 Motherboard Replacement
    1. ATT CL4940 Motherboard Replacement, Motherboard: step 1, image 1 of 2 ATT CL4940 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Disconnect the phone line and power cord from the back cover of the device.
      • Disconnect the phone cable from the side of the device.
      Ask FixBot
    2. ATT CL4940 Motherboard Replacement: step 2, image 1 of 1
      • Turn the device over on its front so the back cover is facing you.
      • Use a bit driver to remove all five 4mm X 10mm Phillips head screws from the back cover.
      Ask FixBot
    3. ATT CL4940 Motherboard Replacement: step 3, image 1 of 3 ATT CL4940 Motherboard Replacement: step 3, image 2 of 3 ATT CL4940 Motherboard Replacement: step 3, image 3 of 3
      • Using a metal spudger, start at the bottom of the device to separate the top cover from the back cover.
      • Work the spudger between the top and back covers of the device starting downwards, then to each side, and finally upwards.
      • There are brackets every few inches along the edge of the device which may be difficult to pull apart.
      • The top and back cover will separate and the internals will be accessible.
      Ask FixBot
    4. ATT CL4940 Motherboard Replacement: step 4, image 1 of 1
      • Use a bit driver to remove all five 5mm X 5mm Phillips head Motherboard screws.
      Ask FixBot
    5. ATT CL4940 Motherboard Replacement: step 5, image 1 of 2 ATT CL4940 Motherboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Lift the motherboard upwards as shown in the first image.
      • Use a de-soldering pump to disconnect the electric wires by de-soldering them.
      Ask FixBot
Hongkun Zhu
263 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Spring 2016 Member of IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Members
48 Guides authored
2 Guide Comments
But no option for ordering a replacement motherboard! Did the author get the part off of a scrapped unit?
Bruce England - Reply Share
It should be noted that the motherboard displayed is the original version. Clearly due to issues related to the AC power supply section, AT&T revised this model to use a DC power supply. What I would like to know is why do so many of these fail with the message "NO AC POWER" when the power supply is indeed working properly. In those events, the display works, the cpu does to (as per the message), and the phone will dial. Speakerphone, and other enhancements (including the answering machine) will NOT work. The reason to recover one of these is to get valuable messages off it. So, for anyone who contributed to this or anyone who might know, what is the fix for this? This seems to happen after utility power issues. Personally, I suspect that there are two power supply areas on this motherboard; one that continues to work and another that appears to fail. It could also be that there is a circuit to detect AC power failure and that detection circuit itself is damaged. This needs a fix. Thanks.
Ifix1stifpossible - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 1,178
