Up to 20% off select tools
ATT CL4940 Internal Microphone Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
106
All Time:
1,772
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you are unable to hear anything during hands free calling, the internal speaker may need to be replaced. This guide will teach you how to disassemble your AT&T CL4940 corded answering system, and how to replace the speaker used for hands free calling. This is a fairly simple process, and it can be accomplished with minimal technical expertise.
    1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: step 1, image 1 of 2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: step 1, image 2 of 2
      • Unplug your device before beginning disassembly.
      • Remove the phone line and the power cord from the back of the device.
      • Remove the phone cable from the side of the device.
      Ask FixBot
    2. ATT CL4940 Internal Microphone Replacement: step 2, image 1 of 1
      • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
      Ask FixBot
    3. ATT CL4940 Internal Microphone Replacement: step 3, image 1 of 3 ATT CL4940 Internal Microphone Replacement: step 3, image 2 of 3 ATT CL4940 Internal Microphone Replacement: step 3, image 3 of 3
      • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
      • Work your way across the bottom of the device, then to each side, and finally to the top.
      • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
      • The top and bottom pieces should separate, and the internals of the device will now be accessible.
      Ask FixBot
    4. ATT CL4940 Internal Microphone Replacement: step 4, image 1 of 1
      • Using wire cutters, sever both the red and the black wires connected to the microphone.
      • To remove the microphone from the device, gently wiggle it while pulling it apart.
      Ask FixBot
Author
with
Charles Moore
201 Reputation
2 Guides authored
IUPUI, Team 2-2, Harley Spring 2016 Member of IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Members
48 Guides authored
1 Guide Comment
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 106
All Time: 1,772
