Up to 20% off select tools
ATT CL2940 Back Panel Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
96
All Time:
1,070
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a prerequisite guide to replacing the components in an ATT CL2490 phone. In order to get to these components, the back panel must be removed. This guide shows how to remove the back panel safely and effectively.
    1. ATT CL2940 Back Panel Replacement, Back Panel: step 1, image 1 of 3 ATT CL2940 Back Panel Replacement, Back Panel: step 1, image 2 of 3 ATT CL2940 Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
      Ask FixBot
    2. ATT CL2940 Back Panel Replacement: step 2, image 1 of 3 ATT CL2940 Back Panel Replacement: step 2, image 2 of 3 ATT CL2940 Back Panel Replacement: step 2, image 3 of 3
      • Slide the metal spudger into the crack and continue around to the front panel of the phone.
      • Be careful not to break the clips that hold the back panel to the front panel.
      Ask FixBot
    3. ATT CL2940 Back Panel Replacement: step 3, image 1 of 1
      • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
      Ask FixBot
Author
with
Charles Messmore
577 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 96
All Time: 1,070
