ASUS ZenWatch Motherboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
102
All Time:
2,195
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Step-by-step guide in removing and replacing a faulty motherboard.
Tools
    1. ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: step 1, image 1 of 2 ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: step 1, image 2 of 2
      • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
      Ask FixBot
    1. ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 1 of 3 ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 2 of 3 ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 3 of 3
      • Use the T5 Torx driver to remove the four screws on the case.
      • Use the magnetic pad to keep all your parts easily contained!
      • The case will pry easily off with just gentle hand pressure
      Ask FixBot
    2. ASUS ZenWatch Motherboard Replacement: step 3, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, gently remove the fabric protecting the battery connection.
      • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
      • Use the heavy duty spudger to gently push the contact towards the top of the case.
      Ask FixBot
    3. ASUS ZenWatch Motherboard Replacement: step 4, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 4, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 4, image 3 of 3
      • Gently pry the battery up with the plastic pry tools
      Ask FixBot
    1. ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 1 of 3 ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 2 of 3 ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 3 of 3
      Buy
      • With the metal tweezers gently remove the fabric covering the connection on bottom right
      • Using the heavy duty plastic spudger pry up on the connection ribbon.
      • There are two connection ports on the single ribbon. Do not use too much force as you may tear ribbon!
      Ask FixBot
    2. ASUS ZenWatch Motherboard Replacement: step 6, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 6, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 6, image 3 of 3
      Heavy-Duty Spudger
      Buy
      • The protective plate is now ready to be safely removed.
      • With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
      • There are tiny notches on plate making it simple to pull up on each side.
      • A small strip of adhesive is on back of plate as well.
      • Remove loosened plate and set aside.
      Ask FixBot
    3. ASUS ZenWatch Motherboard Replacement: step 7, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 7, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 7, image 3 of 3
      • With the 000 Philips screwdriver remove the screw and plastic retainer clips
      Ask FixBot
    4. ASUS ZenWatch Motherboard Replacement: step 8, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 8, image 2 of 2
      • With heavy duty spudger lift up on final connection ribbon located on left corner.
      Ask FixBot
    5. ASUS ZenWatch Motherboard Replacement: step 9, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 9, image 2 of 2
      • With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
      Ask FixBot
3 other people completed this guide.
Wayne McClure
961 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2016 Member of USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Members
72 Guides authored
1 Guide Comment
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 102
All Time: 2,195
