ASUS ZenBook Flip 15 Q528 SSD Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
91
All Time:
1,047
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Whether you have low storage or if you just want to upgrade the storage on your Asus ZenBook Flip 15 Q528 laptop, this is a guide on how to replace the NVMe M.2 SSD drive.
A near-full SSD can significantly decrease performance and prompt "Device Full" errors. Make sure to check and delete any applications, images, or files taking unnecessary space before buying a new SSD. However, if those applications are essential programs, then upgrading the SSD is the move. Upgrading or replacing the SSD with a larger SSD can improve performance and provide more space for files.
Before getting started, be sure to backup your data from the SSD to a separate external drive before attempting. Additionally, remove all charger plugs, and of course power the laptop off.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. ASUS ZenBook Flip 15 Q528 SSD Replacement, SSD: step 1, image 1 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement, SSD: step 1, image 2 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement, SSD: step 1, image 3 of 3
      • Power off the Laptop before starting.
      • Remove all eleven screws on bottom side of laptop:
      • One 7.5 mm Phillips #00
      • Ten 3.6 mm T5 Torx
      Ask FixBot
    2. ASUS ZenBook Flip 15 Q528 SSD Replacement: step 2, image 1 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 2, image 2 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 2, image 3 of 3
      • Apply minimal force as bottom cover could break. Resulting in keyboard and trackpad damage.
      • Slide opening picks under the lower case to loosen the cover.
      • Move clockwise around the cover to loosen the cover evenly.
      • Remove the lower case.
      Ask FixBot
    3. ASUS ZenBook Flip 15 Q528 SSD Replacement: step 3, image 1 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 3, image 2 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 3, image 3 of 3
      • Release the battery connector by pushing upwards on the silver colored lock.
      Ask FixBot
    4. ASUS ZenBook Flip 15 Q528 SSD Replacement: step 4, image 1 of 2 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 4, image 2 of 2
      • Disconnect the battery cable. If not completed correctly further steps could result in minor injury.
      • Push inwards in a pinching motion on the battery cable and slightly pull upwards to disconnect the battery connector.
      Ask FixBot
    5. ASUS ZenBook Flip 15 Q528 SSD Replacement: step 5, image 1 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 5, image 2 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 5, image 3 of 3
      • Remove the single 3 mm Phillips #00 screw securing the SSD.
      • With the SSD screw removed, the SSD will pop up at a shallow angle.
      Ask FixBot
    6. ASUS ZenBook Flip 15 Q528 SSD Replacement: step 6, image 1 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 6, image 2 of 3 ASUS ZenBook Flip 15 Q528 SSD Replacement: step 6, image 3 of 3
      • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
      Ask FixBot
To reassemble, complete the steps in reverse order.
Hopefully, this guide was a useful resource to replace the NVMe M.2 SSD from a ASUS ZenBook Flip 15 Q528 computer within 6 quick and easy steps!
Johnny Rangel
151 Reputation
1 Guide authored
UC Davis, Team 1-4, Morris Fall 2024 Member of UC Davis, Team 1-4, Morris Fall 2024
UCD-MORRIS-F24S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 91
All Time: 1,047
