ASUS ZENFONE 3 Zoom Front Camera Replacement
    1. ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: step 1, image 1 of 2 ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
      Ask FixBot
    2. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 2, image 1 of 1
      • Remove the two 2 mm screws using a Torx T2 screwdriver.
      Ask FixBot
    3. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 3, image 1 of 2 ASUS ZENFONE 3 Zoom Front Camera Replacement: step 3, image 2 of 2
      • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
      • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
      Ask FixBot
    4. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 4, image 1 of 1
      • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
      Ask FixBot
    5. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 5, image 1 of 1
      • Peel back the silver tape.
      Ask FixBot
    6. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 6, image 1 of 1
      • Disconnect the battery connections.
      Ask FixBot
    7. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 7, image 1 of 1
      • Pry and remove the battery.
      • The underside of the battery is adhesive so make sure to pry the battery off gently.
      Ask FixBot
    1. ASUS ZENFONE 3 Zoom Front Camera Replacement, Front Camera: step 8, image 1 of 1
      • Peel the copper adhesive off.
      Ask FixBot
    2. ASUS ZENFONE 3 Zoom Front Camera Replacement: step 9, image 1 of 3 ASUS ZENFONE 3 Zoom Front Camera Replacement: step 9, image 2 of 3 ASUS ZENFONE 3 Zoom Front Camera Replacement: step 9, image 3 of 3
      • Unplug the front camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 61
All Time: 873
