ASUS X552LAV-BBI5N08 Screen Replacement
    1. ASUS X552LAV-BBI5N08 Screen Replacement, Battery: step 1, image 1 of 1
      • Battery is not showed in pictures.
      • Flip the laptop face down.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Screen Replacement: step 2, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 2, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 2, image 3 of 3
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
      Ask FixBot
    1. ASUS X552LAV-BBI5N08 Screen Replacement, Screen: step 3, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: step 3, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: step 3, image 3 of 3
      • Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
      • Slide the bottom panel down and lift it up to remove.
      • Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Screen Replacement: step 4, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 4, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 4, image 3 of 3
      • Use an opening tool to split keyboard from base of the laptop.
      • Make sure to start from one end and go around the edges.
      • Flip laptop to sit on its bottom.
      • Lift keyboard up by the front edge.
      Ask FixBot
    3. ASUS X552LAV-BBI5N08 Screen Replacement: step 5, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 5, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 5, image 3 of 3
      • Flip up the small locking flap for the two ZIF connectors.
      • Unplug the connectors that are keeping the keyboard connected.
      Ask FixBot
    4. ASUS X552LAV-BBI5N08 Screen Replacement: step 6, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 6, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 6, image 3 of 3
      • Flip up the locking flap for the ZIF connector.
      • Unplug the connector.
      Ask FixBot
    5. ASUS X552LAV-BBI5N08 Screen Replacement: step 7, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 7, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Flip laptop to sit with the screen on the bottom.
      • Use tweezers to remove the square decorative sticker from the top of screws from the edge of the screen frame.
      • Remove six 4mm screws (with a JIS #1 screwdriver) from under the stickers and both of the hinges.
      Ask FixBot
    6. ASUS X552LAV-BBI5N08 Screen Replacement: step 8, image 1 of 2 ASUS X552LAV-BBI5N08 Screen Replacement: step 8, image 2 of 2
      • Release hinges with the motion of opening a book.
      Ask FixBot
    7. ASUS X552LAV-BBI5N08 Screen Replacement: step 9, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 9, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 9, image 3 of 3
      • Use an opening tool to pry apart the frame from the edge of the screen
      • Go around the edges til the frame pops off from the screen
      Ask FixBot
    8. ASUS X552LAV-BBI5N08 Screen Replacement: step 10, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 10, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 10, image 3 of 3
      • Remove eight 4mm screws from the corners of the screen using a JIS #000 screwdriver.
      • Flip the screen towards the bottom panel face down.
      Ask FixBot
    9. ASUS X552LAV-BBI5N08 Screen Replacement: step 11, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 11, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 11, image 3 of 3
      • Use tweezers to remove the tape from the top of yellow lock.
      • Open the yellow ZIF connector.
      Ask FixBot
    10. ASUS X552LAV-BBI5N08 Screen Replacement: step 12, image 1 of 2 ASUS X552LAV-BBI5N08 Screen Replacement: step 12, image 2 of 2
      • Remove the tape completely from the back panel.
      Ask FixBot
    11. ASUS X552LAV-BBI5N08 Screen Replacement: step 13, image 1 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 13, image 2 of 3 ASUS X552LAV-BBI5N08 Screen Replacement: step 13, image 3 of 3
      • Remove the casing from the edges of the screen by removing the eight 2mm screws with a JIS #000 screwdriver.
      • Pull the screen up to remove it.
      Ask FixBot
Jason Vo
891 Reputation
5 Guides authored
USF Tampa, Team S17-G1, Boczar Spring 2018 Member of USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 67
All Time: 792
