ASUS X552LAV-BBI5N08 Hard Drive Replacement
    1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Battery is not showed in pictures.
      • Flip the laptop face down.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 3 of 3
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
      Ask FixBot
    1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Start by flipping the laptop face down.
      • Locate the bottom panel. It is at the opposite end of the battery.
      • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 3 of 3
      • Remove bottom panel by lifting it up.
      • Locate the hard drive.
      • It is located in the bottom left corner.
      Ask FixBot
    3. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 3 of 3
      • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
      • Slide the hard drive out to the left.
      Ask FixBot
    4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 6, image 1 of 2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 6, image 2 of 2
      • Lift the hard drive out.
      • Once the hard drive is removed, place the hard drive at a different area.
      Ask FixBot
    5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 3 of 3
      • Place the hard drive on its side.
      • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
      • Lift the hard drive out of the case.
      Ask FixBot
Jason Vo
891 Reputation
5 Guides authored
USF Tampa, Team S17-G1, Boczar Spring 2018 Member of USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 30
All Time: 694
