ASUS X552LAV-BBI5N08 Fan Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
70
All Time:
992
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This is a guide that shows you how to replace the fan for a ASUS X552LAV-BBI5N08 laptop.
Tools
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Battery: step 1, image 1 of 1
      • Battery is not showed in pictures.
      • Flip the laptop face down.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Fan Replacement: step 2, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 2, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 2, image 3 of 3
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
      Ask FixBot
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Fan: step 3, image 1 of 1
      • Locate the bottom panel. It is at the opposite end of the battery.
      • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 Fan Replacement: step 4, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 4, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 4, image 3 of 3
      • Remove bottom panel by lifting it up.
      Ask FixBot
    3. ASUS X552LAV-BBI5N08 Fan Replacement: step 5, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 5, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 5, image 3 of 3
      • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
      • Slide the hard drive out to the left.
      Ask FixBot
    4. ASUS X552LAV-BBI5N08 Fan Replacement: step 6, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 6, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 6, image 3 of 3
      • Use opening tool to split keyboard from base of the laptop.
      • Make sure to start from one end and go around the edges.
      • Use Tri-wing Y1 screwdriver to remove two 12mm screws from battery area.
      Ask FixBot
    5. ASUS X552LAV-BBI5N08 Fan Replacement: step 7, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 7, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 7, image 3 of 3
      • Flip laptop to sit on its bottom.
      • Lift keyboard up by the front edge
      Ask FixBot
    6. ASUS X552LAV-BBI5N08 Fan Replacement: step 8, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 8, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 8, image 3 of 3
      • Flip up the small locking flap for the two ZIF connectors.
      • Unplug connectors that are keeping keyboard connected
      Ask FixBot
    7. ASUS X552LAV-BBI5N08 Fan Replacement: step 9, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 9, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 9, image 3 of 3
      • Flip up the locking flap for the ZIF connector.
      • Unplug the connector that is keeping the keyboard connected.
      Ask FixBot
    8. ASUS X552LAV-BBI5N08 Fan Replacement: step 10, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 10, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 10, image 3 of 3
      • Remove keyboard from laptop.
      • Remove the five 4mm screws (with a Tri-wing Y1 screwdriver) that are both connecting the fan and motherboard.
      • Pull out WiFi from below the cooling fan by lifting the edge nearest to the fan and sliding it towards the fan.
      Ask FixBot
    9. ASUS X552LAV-BBI5N08 Fan Replacement: step 11, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 11, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 11, image 3 of 3
      • Lift yellow ZIF connector from the top of the motherboard to remove the connector.
      • Lift up motherboard from bottom edge towards the screen.
      Ask FixBot
    10. ASUS X552LAV-BBI5N08 Fan Replacement: step 12, image 1 of 2 ASUS X552LAV-BBI5N08 Fan Replacement: step 12, image 2 of 2
      • Unplug the two bundled cable connector from pin sockets below the fan.
      • Remove the motherboard and place on a flat surface.
      • Remove four 4mm screws with a Tri-wing Y1 screwdriver from the CPU.
      Ask FixBot
    11. ASUS X552LAV-BBI5N08 Fan Replacement: step 13, image 1 of 2 ASUS X552LAV-BBI5N08 Fan Replacement: step 13, image 2 of 2
      • Disconnect bundled cable connector from the motherboard
      • Remove fan part from the motherboard.
      Ask FixBot
    12. ASUS X552LAV-BBI5N08 Fan Replacement: step 14, image 1 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 14, image 2 of 3 ASUS X552LAV-BBI5N08 Fan Replacement: step 14, image 3 of 3
      • Remove the black tape from the top of the fan radiator.
      • Remove radiator by tilting it down and pulling it out from the fan.
      Ask FixBot
Jason Vo
891 Reputation
5 Guides authored
USF Tampa, Team S17-G1, Boczar Spring 2018 Member of USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 70
All Time: 992
