ASUS X552LAV-BBI5N08 CD Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
71
All Time:
709
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the CD drive for a ASUS X552LAV-BBI5N08 laptop.
Tools
    1. ASUS X552LAV-BBI5N08 CD Drive Replacement, Battery: step 1, image 1 of 1
      • Battery is not showed in pictures.
      • Flip the laptop face down.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 2, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 2, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 2, image 3 of 3
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
      Ask FixBot
    1. ASUS X552LAV-BBI5N08 CD Drive Replacement, CD Drive: step 3, image 1 of 1
      • Locate the bottom panel. It is at the opposite end of the battery.
      • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
      Ask FixBot
    2. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 4, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 4, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 4, image 3 of 3
      • Remove bottom panel by lifting it up.
      • Locate the hard drive.
      • It is located in the bottom left corner.
      Ask FixBot
    3. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 5, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 5, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 5, image 3 of 3
      • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
      • Slide the hard drive out to the left.
      Ask FixBot
    4. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 6, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 6, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 6, image 3 of 3
      • Use Tri-wing Y1 screwdriver to remove seven 4mm screws from battery area.
      • Use opening tool to split keyboard from base of the laptop.
      • Make sure to start from one end and go around the edges.
      Ask FixBot
    5. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 7, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 7, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 7, image 3 of 3
      • Flip laptop to sit on its bottom.
      • Lift keyboard up by the front edge
      Ask FixBot
    6. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 8, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 8, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 8, image 3 of 3
      • Flip up the small locking flap for the two ZIF connectors.
      • Unplug the connectors that are keeping the keyboard connected.
      Ask FixBot
    7. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 9, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 9, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 9, image 3 of 3
      • Flip up the locking flap for the ZIF connector.
      • Unplug the connector that is keeping the keyboard connected.
      Ask FixBot
    8. ASUS X552LAV-BBI5N08 CD Drive Replacement: step 10, image 1 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 10, image 2 of 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: step 10, image 3 of 3
      • Remove keyboard from laptop.
      • Remove two 4mm screws around CD drive
      • Slide the CD drive out to the right to remove it.
      Ask FixBot
Jason Vo
891 Reputation
5 Guides authored
USF Tampa, Team S17-G1, Boczar Spring 2018 Member of USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 71
All Time: 709
