Up to 20% off select tools
ASUS X550LB-DS71 RAM Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
101
All Time:
1,834
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This laptop has easy access to the RAM slot. Something to keep in mind when choosing the replacement RAM is that there is only one slot for RAM and the laptop requires a minimum of 8 GB to function properly.
    1. ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 1 of 3 ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 2 of 3 ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 3 of 3
      • Make sure to switch off your laptop before starting.
      • Place the laptop on a flat surface with the bottom side facing upwards.
      • Using the Phillips #1 screwdriver, remove the two 4mm screws in the back panel.
      • Using both hands, slide the back panel away from the laptop.
      Ask FixBot
    2. ASUS X550LB-DS71 RAM Replacement: step 2, image 1 of 2 ASUS X550LB-DS71 RAM Replacement: step 2, image 2 of 2
      • Using your thumbs, push the two metal tabs (one on each side) outward until the RAM card pops out.
      • Take the RAM out.
      • To put the RAM back in, push the RAM down until it clicks in place.
      Ask FixBot
2 other people completed this guide.
Author
with
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 101
All Time: 1,834
