ASUS X550LB-DS71 Motherboard Replacement
    1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: step 1, image 1 of 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: step 1, image 2 of 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Make sure to switch off your laptop before starting.
      • Place the laptop on a flat surface with the bottom side facing upwards.
      • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
      • Using both hands, slide the back panel away from the laptop horizontally.
      Ask FixBot
    2. ASUS X550LB-DS71 Motherboard Replacement: step 2, image 1 of 1
      • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
      • At this point, it is advised to disconnect the hard drive from the motherboard.
      Ask FixBot
    3. ASUS X550LB-DS71 Motherboard Replacement: step 3, image 1 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 3, image 2 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 3, image 3 of 3
      • Using the plastic opening tool, open the back cover of the laptop.
      • It is recommended that you start from a corner and run the tool along the edge of the cover.
      • Be careful not to bend or crack the cover.
      Ask FixBot
    4. ASUS X550LB-DS71 Motherboard Replacement: step 4, image 1 of 2 ASUS X550LB-DS71 Motherboard Replacement: step 4, image 2 of 2
      • Locate the three ribbon connectors.
      • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
      • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
      Ask FixBot
    5. ASUS X550LB-DS71 Motherboard Replacement: step 5, image 1 of 2 ASUS X550LB-DS71 Motherboard Replacement: step 5, image 2 of 2
      • Locate the gold ribbon connecting the motherboard to the display.
      • Lift up the tape and disconnect the ribbon.
      Ask FixBot
    6. ASUS X550LB-DS71 Motherboard Replacement: step 6, image 1 of 2 ASUS X550LB-DS71 Motherboard Replacement: step 6, image 2 of 2
      • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
      Ask FixBot
    7. ASUS X550LB-DS71 Motherboard Replacement: step 7, image 1 of 2 ASUS X550LB-DS71 Motherboard Replacement: step 7, image 2 of 2
      • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
      • Disconnect the optical drive from the motherboard by sliding it to the right.
      Ask FixBot
    8. ASUS X550LB-DS71 Motherboard Replacement: step 8, image 1 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 8, image 2 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Flip the motherboard to show the underside.
      • Locate the two square connections attached to the motherboard.
      • Disconnect them using blunt tweezers.
      Ask FixBot
    9. ASUS X550LB-DS71 Motherboard Replacement: step 9, image 1 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 9, image 2 of 3 ASUS X550LB-DS71 Motherboard Replacement: step 9, image 3 of 3
      • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
      • Remove the heat sink from the motherboard.
      Ask FixBot
3 other people completed this guide.
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 130
All Time: 2,928
