Up to 20% off select tools
ASUS X550LB-DS71 Display Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
91
All Time:
1,781
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The display monitor is an output device which presents data on the screen. It is what allows the user to see what inputs they are putting into the device.
    1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 3 of 3
      • Flip open the laptop with the screen facing towards you.
      • Using the plastic opening tool, remove the square tape from the marked locations.
      • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
      Ask FixBot
    2. ASUS X550LB-DS71 Display Panel Replacement: step 2, image 1 of 2 ASUS X550LB-DS71 Display Panel Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, open the front cover of the laptop.
      • It is recommended that you start from a corner and run the tool along the edge of the cover.
      • Be careful not to bend or crack the cover.
      Ask FixBot
    3. ASUS X550LB-DS71 Display Panel Replacement: step 3, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 3, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 3, image 3 of 3
      • Peel off the tape located on the left and right side of the display monitor.
      • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
      Ask FixBot
    4. ASUS X550LB-DS71 Display Panel Replacement: step 4, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 4, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 4, image 3 of 3
      • Place the display monitor face down to expose the ribbon connector.
      • Remove the ribbon connector to separate the display monitor from the rest of the device.
      Ask FixBot
Author
with
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 91
All Time: 1,781
