ASUS X533SA-BHCLN10 LCD Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
71
All Time:
969
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Be sure to follow all steps carefully, keep track of screws, and be gentle with ribbon cables/ plastic clips to successfully repair the LCD screen.
Tools
Video Overview
    1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Power off laptop.
      • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
      Ask FixBot
    2. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 3 of 3
      • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
      • Lift the plastic cover off and set it aside.
      Ask FixBot
    3. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
      Ask FixBot
    4. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 3 of 3
      • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
      Ask FixBot
    5. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 5, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 5, image 2 of 2
      • Insert a plastic opening tool under the edge of the laptop lid.
      • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
      Ask FixBot
    6. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 6, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 6, image 2 of 2
      • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
      Ask FixBot
    7. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 3 of 3
      • Carefully lift up the LCD screen.
      • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
      Ask FixBot
Spencer Lee
283 Reputation
2 Guides authored
IUPUI, Team S2-G4, Harley Fall 2018 Member of IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 71
All Time: 969
