ASUS X533SA-BHCLN10 Hard Drive Replacement
Video Overview
    1. ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: step 1, image 1 of 2 ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn over the laptop on the back panel.
      • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
      Ask FixBot
    2. ASUS X533SA-BHCLN10 Hard Drive Replacement: step 2, image 1 of 2 ASUS X533SA-BHCLN10 Hard Drive Replacement: step 2, image 2 of 2
      • Turn over the laptop with the keyboard facing upwards.
      • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
      Ask FixBot
    3. ASUS X533SA-BHCLN10 Hard Drive Replacement: step 3, image 1 of 2 ASUS X533SA-BHCLN10 Hard Drive Replacement: step 3, image 2 of 2
      • After the laptop is completely pried open carefully remove the keyboard from the laptop.
      • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
      Ask FixBot
    1. ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • The hard drive is closest to the screen, enclosed in a metal plate.
      • Remove all screws holding the hard drive in place.
      Ask FixBot
    2. ASUS X533SA-BHCLN10 Hard Drive Replacement: step 5, image 1 of 1
      • After all screws are removed, carefully disconnect the hard drive and slide it out.
      Ask FixBot
    3. ASUS X533SA-BHCLN10 Hard Drive Replacement: step 6, image 1 of 1
      • Remove screws from the metal plate enclosing hard drive and enclose replacement hard drive in metal plate.
      Ask FixBot
Anthony Bristow
116 Reputation
1 Guide authored
USF Tampa, Team S13-G3, Boczar Fall 2017 Member of USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 105
All Time: 927
