Up to 20% off select tools
ASUS X502CA Webcam Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
83
All Time:
1,624
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If the laptop screen takes a big hit the webcam wires can sometimes become disconnected. If the wires have become dislodged then the webcam can be fixed relatively easily by reconnecting the cables to the webcam. If the webcam breaks, the only option is to replace the webcam.
    1. ASUS X502CA Webcam Replacement, Webcam: step 1, image 1 of 2 ASUS X502CA Webcam Replacement, Webcam: step 1, image 2 of 2
      • Remove the trim from the top of the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
      Ask FixBot
    2. ASUS X502CA Webcam Replacement: step 2, image 1 of 2 ASUS X502CA Webcam Replacement: step 2, image 2 of 2
      • Carefully pull the top of the monitor cover off with bottom still attached, and view the webcam attached by a wire.
      Ask FixBot
    3. ASUS X502CA Webcam Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Unplug webcam wire using fingers or tweezers.
      Ask FixBot
    4. ASUS X502CA Webcam Replacement: step 4, image 1 of 1
      • Pry webcam off using fingers as it is held there with glue.
      Ask FixBot
3 other people completed this guide.
Author
with
Anthony Taylor
354 Reputation
2 Guides authored
Clemson, Team 14-1, Shirley Winter 2015 Member of Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 83
All Time: 1,624
