Up to 20% off select tools
ASUS X502CA Screen Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
90
All Time:
4,131
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
If your Asus laptop screen is cracked it can make it difficult or even impossible to work on the laptop depending on the size of the crack or cracks. The only way to fix this problem is to replace the entire screen.
To do this repair you will need to purchase a new screen and follow the steps in this guide. With no background working with computers you should still be able to complete the repair in under half an hour.
    1. ASUS X502CA Screen Replacement, Screen: step 1, image 1 of 2 ASUS X502CA Screen Replacement, Screen: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
      • Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
      • Screws are black, 50mm in lenght with a 20mm diameter.
      Ask FixBot
    2. ASUS X502CA Screen Replacement: step 2, image 1 of 2 ASUS X502CA Screen Replacement: step 2, image 2 of 2
      • Remove the trim from the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
      Ask FixBot
    3. ASUS X502CA Screen Replacement: step 3, image 1 of 2 ASUS X502CA Screen Replacement: step 3, image 2 of 2
      • Remove the four phillips screws (two on top and two on bottom) using the Phillips #00 screwdriver.
      • The screws are black, 45mm long and 15mm in diameter with a philips head
      Ask FixBot
    4. ASUS X502CA Screen Replacement: step 4, image 1 of 2 ASUS X502CA Screen Replacement: step 4, image 2 of 2
      • Pop the screen out from the top and lay flat on the keyboard.
      • Do not pull screen away from keyboard, as it is still attached by a wire at the bottom.
      Ask FixBot
    5. ASUS X502CA Screen Replacement: step 5, image 1 of 2 ASUS X502CA Screen Replacement: step 5, image 2 of 2
      • Peel off the clear tape that is securing the video cable connector using your fingers or tweezers.
      Ask FixBot
    6. ASUS X502CA Screen Replacement: step 6, image 1 of 2 ASUS X502CA Screen Replacement: step 6, image 2 of 2
      • Unplug the screen using tweezers.
      Ask FixBot
    7. ASUS X502CA Screen Replacement: step 7, image 1 of 1
      • Replace the damage screen with a new one.
      • Replacing the bezel trim requires the bottom to be inside the ends of the hinge cover. Be careful not to break the bezel when doing this.
      • Removing the hinge cover has a chance of breaking the tabs that hold it on. Remove it carefully.
      Ask FixBot
3 other people completed this guide.
Author
with
Anthony Taylor
354 Reputation
2 Guides authored
Clemson, Team 14-1, Shirley Winter 2015 Member of Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 90
All Time: 4,131
