ASUS X502CA Motherboard Replacement
    1. ASUS X502CA Motherboard Replacement, Palm Rest with Keyboard and Touch Pad: step 1, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
      • Use the Phillips #00 screwdriver to remove the four 50mm screws.
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 2, image 1 of 1
      • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
      • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
      Ask FixBot
    3. ASUS X502CA Motherboard Replacement: step 3, image 1 of 2 ASUS X502CA Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
      Ask FixBot
    4. ASUS X502CA Motherboard Replacement: step 4, image 1 of 2 ASUS X502CA Motherboard Replacement: step 4, image 2 of 2
      • Lift Palm Rest away.
      • Replace with new palm rest.
      Ask FixBot
    1. ASUS X502CA Motherboard Replacement, Hard Drive: step 5, image 1 of 2 ASUS X502CA Motherboard Replacement, Hard Drive: step 5, image 2 of 2
      • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 6, image 1 of 2 ASUS X502CA Motherboard Replacement: step 6, image 2 of 2
      • Lift the hard drive and attached bracket up and out.
      Ask FixBot
    3. ASUS X502CA Motherboard Replacement: step 7, image 1 of 3 ASUS X502CA Motherboard Replacement: step 7, image 2 of 3 ASUS X502CA Motherboard Replacement: step 7, image 3 of 3
      • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
      • There are 2 screws on each side.
      Ask FixBot
    1. ASUS X502CA Motherboard Replacement, LED Board: step 8, image 1 of 3 ASUS X502CA Motherboard Replacement, LED Board: step 8, image 2 of 3 ASUS X502CA Motherboard Replacement, LED Board: step 8, image 3 of 3
      • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 9, image 1 of 2 ASUS X502CA Motherboard Replacement: step 9, image 2 of 2
      • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
      • Pull the board up and out.
      Ask FixBot
    1. ASUS X502CA Motherboard Replacement, Left I/O Board: step 10, image 1 of 2 ASUS X502CA Motherboard Replacement, Left I/O Board: step 10, image 2 of 2
      • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
      • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 11, image 1 of 2 ASUS X502CA Motherboard Replacement: step 11, image 2 of 2
      • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
      • Make sure the power strip is disconnected before pulling the board out.
      Ask FixBot
    3. ASUS X502CA Motherboard Replacement: step 12, image 1 of 2 ASUS X502CA Motherboard Replacement: step 12, image 2 of 2
      • Slightly pull the unhinged screen up to free the board and remove it.
      Ask FixBot
    1. ASUS X502CA Motherboard Replacement, Battery: step 13, image 1 of 1
      • Next, locate the battery in the front of laptop (closest to you).
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 14, image 1 of 1
      Buy
      • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
      • If battery is not unplugged, motherboard may shock you.
      Ask FixBot
    3. ASUS X502CA Motherboard Replacement: step 15, image 1 of 2 ASUS X502CA Motherboard Replacement: step 15, image 2 of 2
      • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
      • Once you have removed all six screws carefully lift the battery out and dispose.
      • Each screw is 50 mm in length and 15 mm in diameter.
      Ask FixBot
    1. ASUS X502CA Motherboard Replacement, Motherboard: step 16, image 1 of 2 ASUS X502CA Motherboard Replacement, Motherboard: step 16, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
      • These screws will be marked by diamonds next to the screw holes.
      Ask FixBot
    2. ASUS X502CA Motherboard Replacement: step 17, image 1 of 2 ASUS X502CA Motherboard Replacement: step 17, image 2 of 2
      • Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
      Ask FixBot
    3. ASUS X502CA Motherboard Replacement: step 18, image 1 of 3 ASUS X502CA Motherboard Replacement: step 18, image 2 of 3 ASUS X502CA Motherboard Replacement: step 18, image 3 of 3
      • Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
      Ask FixBot
    4. ASUS X502CA Motherboard Replacement: step 19, image 1 of 1
      • Pull up on the motherboard and take it out.
      Ask FixBot
Christian Spencer
436 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 75
All Time: 1,146
