Up to 20% off select tools
ASUS X502CA Fan Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
78
All Time:
8,570
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Tools
Introduction
Go to step 1 ↓
The fan in your ASUS X502CA keeps components cool while the laptop's running. If your laptop's performance has been dropping, or it feels unusually hot, odds are that the fan is either dirty or damaged.
Before replacement, make sure your fan doesn't just need a good cleaning with an ESD-safe brush and compressed air; gunky blades can't move air efficiently, and often clog with regular use, especially if you have furry pets that like to shed.
If your fan is damaged and not just dirty, it's likely time to replace it altogether.
It is possible that your fan has stopped working due to physical or electrical damage. A replacement fan will need to be purchased before beginning. After purchasing a new fan follow these steps to replace the broken fan of your ASUS X502CA.
Discharge your battery and unplug your laptop before beginning.
    1. ASUS X502CA Fan Replacement, Fan: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to remove:
      • Eight 9 mm screws.
      • Four 5 mm screws.
      Ask FixBot
    2. ASUS X502CA Fan Replacement: step 2, image 1 of 1
      • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
      • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
      Ask FixBot
    3. ASUS X502CA Fan Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
      • Lift the keyboard cover carefully.
      • Disconnect the keyboard and touch-pad ribbons using tweezers.
      Ask FixBot
    4. ASUS X502CA Fan Replacement: step 4, image 1 of 1
      • Remove the keyboard cover panel.
      Ask FixBot
    5. ASUS X502CA Fan Replacement: step 5, image 1 of 1
      • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
      • If these are not unplugged, the motherboard may shock you.
      Ask FixBot
    6. ASUS X502CA Fan Replacement: step 6, image 1 of 1
      • Disconnect the remaining connectors using tweezers or your finger nails.
      Ask FixBot
    7. ASUS X502CA Fan Replacement: step 7, image 1 of 1
      • Remove the six 5 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    8. ASUS X502CA Fan Replacement: step 8, image 1 of 1
      • Flip the motherboard over and away from the screen.
      Ask FixBot
    9. ASUS X502CA Fan Replacement: step 9, image 1 of 1
      • Remove the two 5 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    10. ASUS X502CA Fan Replacement: step 10, image 1 of 1
      • Unplug the fan's power connector using tweezers or your fingernails.
      Ask FixBot
    11. ASUS X502CA Fan Replacement: step 11, image 1 of 1
      • Peel off the marked strip using your fingers.
      Ask FixBot
    12. ASUS X502CA Fan Replacement: step 12, image 1 of 1
      • Lift the fan up and away from the motherboard.
      Ask FixBot
6 other people completed this guide.
Author
with
David Conner
292 Reputation
2 Guides authored
Clemson, Team 14-1, Shirley Winter 2015 Member of Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Members
60 Guides authored
2 Guide Comments
Great tutorial.
Arthur Rumrill - Reply Share
Thanks Bro! :)
Crispino A Meola - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 78
All Time: 8,570
