ASUS X44H-BBR4 Screen Replacement
    1. ASUS X44H-BBR4 Screen Replacement, Battery: step 1, image 1 of 2 ASUS X44H-BBR4 Screen Replacement, Battery: step 1, image 2 of 2
      • Flip the device over.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 2, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 2, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 2, image 3 of 3
      • Slide the right lock button to the unlock position.
      • After it is unlocked, a red line will be visible.
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 3, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 3, image 2 of 2
      • Slide the left lock button into the unlock position and hold.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 4, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 4, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 4, image 3 of 3
      • While holding the left lock button in the unlock position, push the battery from the center away from you.
      Ask FixBot
    1. ASUS X44H-BBR4 Screen Replacement, Hard Drive: step 5, image 1 of 2 ASUS X44H-BBR4 Screen Replacement, Hard Drive: step 5, image 2 of 2
      • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 6, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 6, image 2 of 2
      • Once the screws are removed, slide the back panel away from the computer.
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 7, image 1 of 1
      • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 8, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 8, image 2 of 2
      • Slide the hard drive to the left, unlocking it from its default position.
      Ask FixBot
    5. ASUS X44H-BBR4 Screen Replacement: step 9, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 9, image 2 of 2
      • Pull the hard drive upwards and take it out of its position.
      Ask FixBot
    6. ASUS X44H-BBR4 Screen Replacement: step 10, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 10, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 10, image 3 of 3
      • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
      Ask FixBot
    7. ASUS X44H-BBR4 Screen Replacement: step 11, image 1 of 1
      • Pull upwards on the metal casing and it will come off.
      Ask FixBot
    1. ASUS X44H-BBR4 Screen Replacement, Keyboard: step 12, image 1 of 2 ASUS X44H-BBR4 Screen Replacement, Keyboard: step 12, image 2 of 2
      • Open the laptop to show the keyboard.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 13, image 1 of 1
      • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
      • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 14, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 14, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 14, image 3 of 3
      • Don't pull too hard on the keys otherwise they may fall off.
      • Push the latch away from the keyboard using the spudger point.
      • While pushing the latches use a plastic opening tool and pull up on a key near it.
      • Continue along the rest of the keyboard until it is released at all four latches.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 15, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 15, image 2 of 2
      • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
      • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
      Ask FixBot
    5. ASUS X44H-BBR4 Screen Replacement: step 16, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 16, image 2 of 2
      • Flip the keyboard over to reveal the back of it and what is underneath.
      Ask FixBot
    6. ASUS X44H-BBR4 Screen Replacement: step 17, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 17, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 17, image 3 of 3
      • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
      • Gently pull out the ribbon cable from the connector piece.
      Ask FixBot
    7. ASUS X44H-BBR4 Screen Replacement: step 18, image 1 of 1
      • Remove the keyboard completely.
      Ask FixBot
    1. ASUS X44H-BBR4 Screen Replacement, Front Panel: step 19, image 1 of 3 ASUS X44H-BBR4 Screen Replacement, Front Panel: step 19, image 2 of 3 ASUS X44H-BBR4 Screen Replacement, Front Panel: step 19, image 3 of 3
      • Lift up the black lock holding the ribbon.
      • Using the blue tab, pull out the ribbon.
      • Pull gently on the ribbon to remove the risk of damaging the ribbon.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 20, image 1 of 1
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 21, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 21, image 2 of 2
      • Remove the five 9 mm Phillips head screws with the PH0 bit.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 22, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 22, image 2 of 2
      • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
      Ask FixBot
    5. ASUS X44H-BBR4 Screen Replacement: step 23, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 23, image 2 of 2
      • Pull up on the disk drive and remove.
      Ask FixBot
    6. ASUS X44H-BBR4 Screen Replacement: step 24, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 24, image 2 of 2
      • Close the laptop and flip it over.
      • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
      Ask FixBot
    7. ASUS X44H-BBR4 Screen Replacement: step 25, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 25, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 25, image 3 of 3
      • Flip the device back over and open the laptop.
      • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
      • You should hear clicking sounds as the front panel is being removed from the base.
      Ask FixBot
    8. ASUS X44H-BBR4 Screen Replacement: step 26, image 1 of 1
      • Remove the panel.
      • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
      Ask FixBot
    1. ASUS X44H-BBR4 Screen Replacement, MotherBoard: step 27, image 1 of 2 ASUS X44H-BBR4 Screen Replacement, MotherBoard: step 27, image 2 of 2
      • Remove the 5mm Phillips head screw using the PH0 bit.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 28, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 28, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 28, image 3 of 3
      • Pull up on the tape holding the tan cable in place.
      • While holding the tape push up on each side of the cable connector to disconnect it.
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 29, image 1 of 1
      • Gently pull out the cable connector.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 30, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 30, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 30, image 3 of 3
      • Gently pull out the USB connector attached to the motherboard.
      Ask FixBot
    5. ASUS X44H-BBR4 Screen Replacement: step 31, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 31, image 2 of 2
      • Remove the red and white wire connector next to the fan.
      Ask FixBot
    6. ASUS X44H-BBR4 Screen Replacement: step 32, image 1 of 1
      • Take out the motherboard
      • There are still two wires connected to the bottom of the motherboard so remove carefully.
      Ask FixBot
    7. ASUS X44H-BBR4 Screen Replacement: step 33, image 1 of 1
      • Flip the motherboard over next to the laptop base.
      Ask FixBot
    8. ASUS X44H-BBR4 Screen Replacement: step 34, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 34, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 34, image 3 of 3
      • Remove the white and black wire.
      • The motherboard is not completely separated from the base of the computer.
      Ask FixBot
    1. ASUS X44H-BBR4 Screen Replacement, Screen: step 35, image 1 of 2 ASUS X44H-BBR4 Screen Replacement, Screen: step 35, image 2 of 2
      • Remove the four 9 mm Phillips head screws that hold the screen to the base with the PH0 bit.
      Ask FixBot
    2. ASUS X44H-BBR4 Screen Replacement: step 36, image 1 of 1
      • Lift up the screen from the base.
      Ask FixBot
    3. ASUS X44H-BBR4 Screen Replacement: step 37, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 37, image 2 of 2
      • Remove the rubber pads with the nylon or metal spudger to reveal two 5mm Phillips head screws.
      Ask FixBot
    4. ASUS X44H-BBR4 Screen Replacement: step 38, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 38, image 2 of 2
      • Remove the two 5mm Phillips head screws with the PH0 bit.
      Ask FixBot
    5. ASUS X44H-BBR4 Screen Replacement: step 39, image 1 of 2 ASUS X44H-BBR4 Screen Replacement: step 39, image 2 of 2
      • Pry open the screen cover by running the nylon or metal spudger in the seams.
      • Remove the cover.
      Ask FixBot
    6. ASUS X44H-BBR4 Screen Replacement: step 40, image 1 of 1
      • Remove the eight 5mm Phillips head screws holding down the screen with the PH0 bit.
      Ask FixBot
    7. ASUS X44H-BBR4 Screen Replacement: step 41, image 1 of 1
      • Lift up the screen.
      • Carefully remove the screen because there are still wires connected to the screen
      Ask FixBot
    8. ASUS X44H-BBR4 Screen Replacement: step 42, image 1 of 3 ASUS X44H-BBR4 Screen Replacement: step 42, image 2 of 3 ASUS X44H-BBR4 Screen Replacement: step 42, image 3 of 3
      • Lift up the tape piece securing the ribbon to the screen.
      • Pull out the ribbon.
      • Remove the screen completely from the frame.
      Ask FixBot
3 other people completed this guide.
Devaj Ramsamooj
824 Reputation
5 Guides authored
UMass Dartmouth, Team 4-3, Catania Fall 2015 Member of UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 105
All Time: 1,137
