ASUS X44H-BBR4 Keyboard Replacement
    1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: step 1, image 1 of 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Open the laptop to show the keyboard.
      Ask FixBot
    2. ASUS X44H-BBR4 Keyboard Replacement: step 2, image 1 of 1
      • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
      • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
      Ask FixBot
    3. ASUS X44H-BBR4 Keyboard Replacement: step 3, image 1 of 3 ASUS X44H-BBR4 Keyboard Replacement: step 3, image 2 of 3 ASUS X44H-BBR4 Keyboard Replacement: step 3, image 3 of 3
      • Don't pull too hard on the keys otherwise they may fall off.
      • Push the latch away from the keyboard using the spudger point.
      • While pushing the latches use a plastic opening tool and pull up on a key near it.
      • Continue along the rest of the keyboard until it is released at all four latches.
      Ask FixBot
    4. ASUS X44H-BBR4 Keyboard Replacement: step 4, image 1 of 2 ASUS X44H-BBR4 Keyboard Replacement: step 4, image 2 of 2
      • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
      • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
      Ask FixBot
    5. ASUS X44H-BBR4 Keyboard Replacement: step 5, image 1 of 2 ASUS X44H-BBR4 Keyboard Replacement: step 5, image 2 of 2
      • Flip the keyboard over to reveal the back of it and what is underneath.
      Ask FixBot
    6. ASUS X44H-BBR4 Keyboard Replacement: step 6, image 1 of 3 ASUS X44H-BBR4 Keyboard Replacement: step 6, image 2 of 3 ASUS X44H-BBR4 Keyboard Replacement: step 6, image 3 of 3
      • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
      • Gently pull out the ribbon cable from the connector piece.
      Ask FixBot
    7. ASUS X44H-BBR4 Keyboard Replacement: step 7, image 1 of 1
      • Remove the keyboard completely.
      Ask FixBot
4 other people completed this guide.
Kelly Merlo
500 Reputation
2 Guides authored
UMass Dartmouth, Team 4-3, Catania Fall 2015 Member of UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 112
All Time: 1,668
