ASUS X42J Motherboard Replacement
    1. ASUS X42J Motherboard Replacement, Keyboard: step 1, image 1 of 1
      Tool used on this step:
      Metal Spudger
      $2.99
      Buy
      • Make sure your device is unplugged and turned off before proceeding.
      • Using a Spudger, gently pry up the keyboard.
      Ask FixBot
    2. ASUS X42J Motherboard Replacement: step 2, image 1 of 2 ASUS X42J Motherboard Replacement: step 2, image 2 of 2
      Nylon Tipped Tweezers
      Buy
      • Rotate the keyboard to face downward.
      • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
      Ask FixBot
    1. ASUS X42J Motherboard Replacement, Disk Drive: step 3, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
      Ask FixBot
    2. ASUS X42J Motherboard Replacement: step 4, image 1 of 1
      • Slide the disk drive out of the device.
      Ask FixBot
    1. ASUS X42J Motherboard Replacement, Motherboard: step 5, image 1 of 3 ASUS X42J Motherboard Replacement, Motherboard: step 5, image 2 of 3 ASUS X42J Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
      Ask FixBot
    2. ASUS X42J Motherboard Replacement: step 6, image 1 of 2 ASUS X42J Motherboard Replacement: step 6, image 2 of 2
      • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
      Ask FixBot
    3. ASUS X42J Motherboard Replacement: step 7, image 1 of 2 ASUS X42J Motherboard Replacement: step 7, image 2 of 2
      Metal Spudger
      $2.99
      Buy
      • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
      Ask FixBot
    4. ASUS X42J Motherboard Replacement: step 8, image 1 of 1
      • Unscrew and remove the marked screws.
      Ask FixBot
    5. ASUS X42J Motherboard Replacement: step 9, image 1 of 1
      • Separate the connectors.
      Ask FixBot
    6. ASUS X42J Motherboard Replacement: step 10, image 1 of 2 ASUS X42J Motherboard Replacement: step 10, image 2 of 2
      • Remove the motherboard from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 69
All Time: 1,303
