ASUS VivoBook Flip TP501U Keyboard Panel Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
72
All Time:
1,650
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The keyboard panel contains both the keyboard and the touchpad of the ASUS VivoBook Flip TP501U. Removing it also grants access to the internals of the device, which allows for the replacement of other components. This guide will walk you through the steps of replacing the keyboard panel.
Tools
    1. ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: step 1, image 1 of 2 ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: step 1, image 2 of 2
      • Open the laptop until it is flat and lay it screen down.
      • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
      • Remove two 4.8mm Phillips from the corners of the device.
      Ask FixBot
    2. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: step 2, image 1 of 1
      • Turn the device face up.
      • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
      • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
      Ask FixBot
    3. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: step 3, image 1 of 1
      • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
      • Remove the keyboard panel completely.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 72
All Time: 1,650
