ASUS VivoBook Flip TP501U Battery Replacement
    1. ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: step 1, image 1 of 2 ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: step 1, image 2 of 2
      • Open the laptop until it is flat and lay it screen down.
      • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
      • Remove two 4.8mm Phillips from the corners of the device.
      Ask FixBot
    2. ASUS VivoBook Flip TP501U Battery Replacement: step 2, image 1 of 1
      • Turn the device face up.
      • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
      • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
      Ask FixBot
    3. ASUS VivoBook Flip TP501U Battery Replacement: step 3, image 1 of 1
      • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
      • Remove the keyboard panel completely.
      Ask FixBot
    1. ASUS VivoBook Flip TP501U Battery Replacement, Battery: step 4, image 1 of 2 ASUS VivoBook Flip TP501U Battery Replacement, Battery: step 4, image 2 of 2
      • Remove the white ribbon cable shown by pulling on the blue tab.
      Ask FixBot
    2. ASUS VivoBook Flip TP501U Battery Replacement: step 5, image 1 of 2 ASUS VivoBook Flip TP501U Battery Replacement: step 5, image 2 of 2
      • Remove the black cable found beneath the white ribbon cable that you just removed.
      Ask FixBot
    3. ASUS VivoBook Flip TP501U Battery Replacement: step 6, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the wire bundle shown.
      Ask FixBot
    4. ASUS VivoBook Flip TP501U Battery Replacement: step 7, image 1 of 2 ASUS VivoBook Flip TP501U Battery Replacement: step 7, image 2 of 2
      • Unscrew the 3/16 inch long screw that holds the battery to the chassis using a #00 Phillips Screwdriver.
      • Lift the battery from the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 46
All Time: 2,771
