Up to 20% off select tools
ASUS UX50V-RX05 Motherboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
92
All Time:
1,276
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
    1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 3 of 3
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
      Ask FixBot
    2. ASUS UX50V-RX05 Motherboard Replacement: step 2, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 2, image 2 of 2
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
      Ask FixBot
    3. ASUS UX50V-RX05 Motherboard Replacement: step 3, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 3, image 2 of 2
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
      Ask FixBot
    1. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 3 of 3
      • Remove the thirteen 5 mm J0 screws from the back of the laptop.
      • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
      Ask FixBot
    2. ASUS UX50V-RX05 Motherboard Replacement: step 5, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 5, image 2 of 2
      • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
      Ask FixBot
    3. ASUS UX50V-RX05 Motherboard Replacement: step 6, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 6, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 6, image 3 of 3
      • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
      • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
      Ask FixBot
    4. ASUS UX50V-RX05 Motherboard Replacement: step 7, image 1 of 1
      • Carefully lift and remove the plastic cover to avoid damaging anything.
      Ask FixBot
    1. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: step 8, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: step 8, image 2 of 2
      • Remove the four 5 mm J0 screws surrounding the Optical Drive.
      • Remove the optical drive by pulling it out and away from the connector.
      Ask FixBot
    1. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 3 of 3
      • Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
      Ask FixBot
    2. ASUS UX50V-RX05 Motherboard Replacement: step 10, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 10, image 2 of 2
      • Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
      Ask FixBot
    3. ASUS UX50V-RX05 Motherboard Replacement: step 11, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 11, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 11, image 3 of 3
      • Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
      Ask FixBot
    4. ASUS UX50V-RX05 Motherboard Replacement: step 12, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 12, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 12, image 3 of 3
      • Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
      • Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
      Ask FixBot
    5. ASUS UX50V-RX05 Motherboard Replacement: step 13, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 13, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 13, image 3 of 3
      • Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
      • Using the Spudger, remove the connector towards the bottom of the motherboard.
      • Remove the motherboard from the casing.
      Ask FixBot
2 other people completed this guide.
Author
with
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
72 Guides authored
1 Guide Comment
From your knowledge is that mother board from the asus ux50v upgrade-able? is the processor integrated into the board?
A Snow - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 92
All Time: 1,276
