Up to 20% off select tools
ASUS UX50V-RX05 Keyboard Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
95
All Time:
1,000
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is how you remove the keyboard on an Asus UX50V-RX05 Laptop.
    1. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
      Ask FixBot
    2. ASUS UX50V-RX05 Keyboard Replacement: step 2, image 1 of 2 ASUS UX50V-RX05 Keyboard Replacement: step 2, image 2 of 2
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
      Ask FixBot
    3. ASUS UX50V-RX05 Keyboard Replacement: step 3, image 1 of 2 ASUS UX50V-RX05 Keyboard Replacement: step 3, image 2 of 2
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
      Ask FixBot
Author
with
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 95
All Time: 1,000
