ASUS U57A-BBL4 Front Panel Assembly Replacement
    1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is completely shut down to avoid data complications.
      • Hold the left lock switch towards the left to the unlock option.
      Ask FixBot
    2. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 2, image 1 of 1
      • Toggle the right lock switch to the unlock option.
      Ask FixBot
    3. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 3, image 1 of 1
      • Gently slide the battery out while still holding the left unlock switch.
      Ask FixBot
    1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: step 4, image 1 of 2 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: step 4, image 2 of 2
      • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
      • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
      Ask FixBot
    2. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 5, image 1 of 1
      • Remove the RAM by lifting up with your fingers and sliding it out towards you.
      Ask FixBot
    3. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 6, image 1 of 1
      • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
      • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
      Ask FixBot
    4. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 7, image 1 of 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: step 7, image 2 of 2
      • Remove the hard drive by sliding it to the left and lifting up.
      Ask FixBot
    5. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 8, image 1 of 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: step 8, image 2 of 2
      • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
      • Flip the laptop right-side up and open the screen.
      Ask FixBot
    6. ASUS U57A-BBL4 Front Panel Assembly Replacement: step 9, image 1 of 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: step 9, image 2 of 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: step 9, image 3 of 3
      • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
      • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
      • The front panel is now loose from the laptop.
      Ask FixBot
Isabella Bernardi
698 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 122
All Time: 656
