ASUS U57A-BBL4 Display Assembly Replacement
    1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
      • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
      Ask FixBot
    2. ASUS U57A-BBL4 Display Assembly Replacement: step 2, image 1 of 1
      • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
      Ask FixBot
    3. ASUS U57A-BBL4 Display Assembly Replacement: step 3, image 1 of 1
      • Starting from one of the corners, use your fingers to pry the bezel from the screen.
      • There is a popping sound when the bezel is loosened from the screen.
      Ask FixBot
    4. ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 1 of 3 ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 2 of 3 ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 3 of 3
      • Remove the top two 2 mm Phillips head screws.
      • Remove the four 2 mm Phillips head screws on the bottom.
      • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
      • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
      Ask FixBot
    5. ASUS U57A-BBL4 Display Assembly Replacement: step 5, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement: step 5, image 2 of 2
      • Don't tear off the bottom of the screen or you might damage the connector cable.
      • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
      Ask FixBot
    6. ASUS U57A-BBL4 Display Assembly Replacement: step 6, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement: step 6, image 2 of 2
      • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
      • Gently slide the cable out of the ridges to free the screen from the casing.
      Ask FixBot
Isabella Bernardi
698 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 116
All Time: 760
