ASUS U52F-BBG6 Wi-Fi Chip Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
92
All Time:
916
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace your Wi-Fi chip. Keep in mind it will take a lot of effort when removing the back panel.
Tools
    1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Back Cover: step 1, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement, Back Cover: step 1, image 2 of 2
      • Flip the laptop over to the back.
      • Slide the right latch to unlock, then simultaneously slide the left latch outward while pulling the battery out.
      Ask FixBot
    2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 2, image 1 of 3 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 2, image 2 of 3 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 2, image 3 of 3
      • Unscrew all twelve 3mm Phillips screws with the J1 screwdriver.
      • Unscrew two 3mm Phillips screws on the black panel using the PH0 screwdriver.
      • Lift the black panel upward by inserting your fingernail in the space provided.
      Ask FixBot
    3. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 3, image 1 of 3 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 3, image 2 of 3 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 3, image 3 of 3
      • In the RAM and hard drive compartment, unscrew the four 3mm Phillips screws using the J1 screwdriver.
      • Gently pull out the hard drive.
      Ask FixBot
    4. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 4, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 4, image 2 of 2
      • Unscrew six 3mm Phillips screws in the RAM and hard drive compartment with the J1 screwdriver.
      Ask FixBot
    5. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 5, image 1 of 1
      • Pull the CD drive outward with your left hand.
      Ask FixBot
    6. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 6, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 6, image 2 of 2
      • Insert and gently twist the flat metal spudger between the keyboard assembly and the bottom plastic cover so that a small seam is opened.
      • Put in the metal spudger in the seam to hold its place while twisting and levering the flat metal spudger along the whole keyboard.
      • Be careful not to hit any of the internals with the metal spudger. The regular black nylon spudger should be used whenever possible, especially around batteries or sensitive internal components.
      • You will need add a lot of pressure to open the laptop. Expect to hear snaps as the clips holding the two pieces are released.
      • Slowly pry off the back
      Ask FixBot
    1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Keyboard: step 7, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement, Keyboard: step 7, image 2 of 2
      • Unlatch the clip attaching the white flattened flexible cord with a blue tip to the circuit board with your thumb.
      • Pull out the white flattened cord.
      Ask FixBot
    2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 8, image 1 of 1
      • Pull back yellow tape attaching the metal colored flexible flattened cord to the circuit board.
      • Lift up the latch at the end of the cord.
      • Pull out the cord to release the keyboard.
      Ask FixBot
    1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Wi-fi Chip: step 9, image 1 of 1
      • Find the Wi-Fi chip circuit board, which has a white sticker on it and is connected to a black and white wire.
      Ask FixBot
    2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 10, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 10, image 2 of 2
      • Unscrew the two 3mm Phillips screws using a J1 screwdriver to release the Wi-Fi chip.
      Ask FixBot
    3. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 11, image 1 of 2 ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 11, image 2 of 2
      • Pull out the Wi-Fi chip
      Ask FixBot
    4. ASUS U52F-BBG6 Wi-Fi Chip Replacement: step 12, image 1 of 1
      • Pull off both wires from the chip.
      • It's advised to label the wires to remember where each colored wire connects to on the circuit board.
      Ask FixBot
Ashley DeHuff
852 Reputation
8 Guides authored
CSU Fullerton, Team 1-3, Bruce Fall 2016 Member of CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 92
All Time: 916
