Up to 20% off select tools
ASUS U52F-BBG6 Camera Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
76
All Time:
795
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace your camera assembly that holds the webcam. This is a fairly easy replacement just keep in mind parts of the computer are fragile.
    1. ASUS U52F-BBG6 Camera Replacement, Camera: step 1, image 1 of 2 ASUS U52F-BBG6 Camera Replacement, Camera: step 1, image 2 of 2
      • Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
      • The cushions may no longer be adherent and a bit of glue may be needed to reattach them.
      • Unscrew the two 3mm Phillips screws on the bottom of the frame with the J1 screwdriver.
      • The two 3mm Phillips screws are hidden behind the cushions.
      Ask FixBot
    2. ASUS U52F-BBG6 Camera Replacement: step 2, image 1 of 2 ASUS U52F-BBG6 Camera Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
      • Be careful not to scratch the screen with the opening tool.
      • Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
      • The snaps that hold the frame to the shell are fragile.
      • Continue to pry with the opening tool or use your fingers until the top portion of the frame releases.
      Ask FixBot
    3. ASUS U52F-BBG6 Camera Replacement: step 3, image 1 of 2 ASUS U52F-BBG6 Camera Replacement: step 3, image 2 of 2
      • Pull the screen frame towards you so that the seam between the frame and the bottom of the screen is opened.
      • Insert the opening tool into the seam.
      • Peel the metallic strip with your finger and thumb until it's fully off.
      • Place the remaining frame down on the keyboard.
      Ask FixBot
    4. ASUS U52F-BBG6 Camera Replacement: step 4, image 1 of 2 ASUS U52F-BBG6 Camera Replacement: step 4, image 2 of 2
      • Use the pointed side of the black spudger to remove the metallic stickers by the circuit board of the camera above the screen.
      • Do not remove the sticker completely.
      Ask FixBot
    5. ASUS U52F-BBG6 Camera Replacement: step 5, image 1 of 2 ASUS U52F-BBG6 Camera Replacement: step 5, image 2 of 2
      • Carefully lift the camera's circuit board by using the flat side of the spudger.
      • The adherent on the camera's circuit board is very sticky.
      Ask FixBot
    6. ASUS U52F-BBG6 Camera Replacement: step 6, image 1 of 2 ASUS U52F-BBG6 Camera Replacement: step 6, image 2 of 2
      • Holding the camera's circuit board with your right hand, use your left index finger and thumb to unplug the micro white hook from the camera.
      • The micro white hook is fragile.
      Ask FixBot
Author
with
Ashley DeHuff
852 Reputation
8 Guides authored
CSU Fullerton, Team 1-3, Bruce Fall 2016 Member of CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 76
All Time: 795
