Up to 20% off select tools
ASUS U46E-RAL7 Back Panel Removal Guide
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,343
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, the user will be able to follow step-by-step instructions for replacing the back panel of the ASUS U46E-RAL7 Laptop.
    1. ASUS U46E-RAL7 Back Panel Removal Guide, ASUS U46E-RAL7 Back Panel Removal Guide: step 1, image 1 of 1
      • Remove two (2) 9mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
      • Remove two (2) 7mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
      • Remove six (6) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
      • Remove three (3) 3mm x 3mm screws with the size 0 Phillips head screwdriver.
      • Remove one (1) 4mm x 4mm screws with the size 0 Phillips head screwdriver.
      Ask FixBot
    2. ASUS U46E-RAL7 Back Panel Removal Guide: step 2, image 1 of 2 ASUS U46E-RAL7 Back Panel Removal Guide: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the rubber caps (4) with the tweezers. If the rubber caps are not removed easily, pull gently. The caps are glued down.
      • Remove four (4) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
      Ask FixBot
    3. ASUS U46E-RAL7 Back Panel Removal Guide: step 3, image 1 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 3, image 2 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 3, image 3 of 3
      • Remove the L shaped panel with the plastic opening tool by inserting it into the indent along the USB port side of the laptop.
      • Push down gently on the plastic opening tool until part of the panel pops up.
      • Use your fingers to pop the panel off.
      Ask FixBot
    4. ASUS U46E-RAL7 Back Panel Removal Guide: step 4, image 1 of 1
      • Remove three (3) 5mm x 4mm screws with the size 0 Phillips head screwdriver.
      • Remove one (1) 4mm x 4mm (closest to the battery) screw with the size 0 Phillips head screwdriver.
      Ask FixBot
    5. ASUS U46E-RAL7 Back Panel Removal Guide: step 5, image 1 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 5, image 2 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 5, image 3 of 3
      • Remove the CD ROM drive by inserting the plastic opening tool between the drive and the laptop's side.
      • Push down gently to eject the drive.
      • Pull the drive straight out to remove the part from the laptop.
      Ask FixBot
    6. ASUS U46E-RAL7 Back Panel Removal Guide: step 6, image 1 of 1
      Ask FixBot
    7. ASUS U46E-RAL7 Back Panel Removal Guide: step 7, image 1 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 7, image 2 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 7, image 3 of 3
      • Flip the device so that the laptop will open away from you to remove the hinge cover behind the screen.
      • Place index fingers underneath the hinge cover and gently pull up.
      • The cover will pop off easily with a click.
      • Remove five (5) 5mm x 4mm screws from the hinge compartments of the device with the size 0 phillips head screwdriver.
      Ask FixBot
    8. ASUS U46E-RAL7 Back Panel Removal Guide: step 8, image 1 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 8, image 2 of 3 ASUS U46E-RAL7 Back Panel Removal Guide: step 8, image 3 of 3
      • Open the screen.
      • Carefully lift the keyboard panel. The keyboard will be attached to the motherboard by two ribbons.
      • To disconnect the ribbons, use your fingernails to push down gently on the protruding plastic at the base of the connector. There is a soft click and ribbon releases. Repeat for the other ribbon.
      Ask FixBot
    9. ASUS U46E-RAL7 Back Panel Removal Guide: step 9, image 1 of 2 ASUS U46E-RAL7 Back Panel Removal Guide: step 9, image 2 of 2
      • Remove the keyboard from the computer to reveal the motherboard.
      Ask FixBot
Author
with
Vanessa Ng
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,343
